where in the world is /etc/crypttab
Postby complication » Fri Apr 29, 2005 2:50 am
I wanna set up a root filesystem that is encrypted.
I am running slackware 10.
I installed dm-setup and I can encrypt drives just fine. BUT there is no /etc/crypttab on my system :< so I cant encrypt my root cause I need that.
So where does /etc/crypttab come from , and does anyone have any pointers or guides as to how to encrypt my root fs.
Thanks
complication
RE: where in the world is /etc/crypttab
Postby evilnick » Fri May 06, 2005 4:51 pm
don't you mean /etc/cryptotab?
you just need an entry like:
/dev/loop1 /dev/hda1 /crypt ext3 aes noatime
AFAIR - long time since I used slack now
evilnick
Users browsing this forum: Majestic-12 [Bot] and 1 guest
