Fedora 19 Add remove software
Postby pk_fox » Mon Sep 16, 2013 2:01 pm
Hi All, just installed Fed 19 and the Add/Remove Software icon has vanished from the System section - any ideas where it is ?
pk_fox
Postby MartyBartfast » Mon Sep 16, 2013 7:17 pm
I'm using xfce on Fedora 19, and it's under Administration and is called Software.
MartyBartfast
Postby pk_fox » Mon Sep 16, 2013 7:56 pm
MartyBartfast wrote:I'm using xfce on Fedora 19, and it's under Administration and is called Software.
Don't know what I'm using ( probably Gnome ) and its nowhere to be seen.
pk_fox
