nginx, php and localhost Ubuntu 13.04
Postby duff » Wed Sep 11, 2013 3:34 pm
Hi Everyone
Long time since I posted here.
I'm having a problem with nginx and php on ubuntu 13.04.
I'm very new to web development and php. I want to be able to read a text file (tab or comma sep) on the server using php and pass the resulting array to js for further client side processing.
In order to get nginx to play with php Google tells me I have to install php5-fpm and set this up. So I have followed a couple of web tutorials (tell you more or less the same thing) but the setup isn't working.
Relevant configurations are (note I've left out a load of stuff that's commented out in these files):
Nginx default file
server {
   listen 80;
   listen [::]:80 default_server ipv6only=on;
   # Make site accessible from http://localhost/
   server_name localhost;
      root /usr/share/nginx/html;
      index index.php index.html index.htm;
   location / {
      # First attempt to serve request as file, then
      # as directory, then fall back to displaying a 404.
      try_files $uri $uri/ /index.html;
      # Uncomment to enable naxsi on this location
      # include /etc/nginx/naxsi.rules
   location /doc/ {
      alias /usr/share/doc/;
      autoindex on;
      allow 127.0.0.1;
      allow ::1;
      deny all;
   # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
   location ~ \.php$ {
      try_files $uri=404;
      fastcgi_split_path_info ^(.+\.php)(/.+)$;
   #   # NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
   #   # With php5-cgi alone:
   #   fastcgi_pass 127.0.0.1:9000;
   #   # With php5-fpm:
      fastcgi_pass unix:/var/run/php5-fpm.sock;
      fastcgi_index index.php;
      include fastcgi_params;
In the
/etc/php5/fpm/php.ini
file I uncommented and changed the line
cgi.fix_pathinfo=1
to
cgi.fix_pathinfo=0;
(as per above)
I created a test file:
cd /usr/share/nginx/html
sudo su
echo '<?php phpinfo(); ?>' > info.php
and this is fine
Both nginx and php5-fpm were restarted.
Browsing to
http://localhost
let's me see the nginx default page (so I know nginx is working) but
http://localhost/info.php
does not display the page but only asks if I want to download the info.php file.
Can anyone help with this? I'd like to get nginx and php to play nice on my local machine so I can get the hang of server side programming.
Best
duff
duff
Postby leke » Wed Sep 11, 2013 5:22 pm
I would be interested to see the output of...
ls -l /usr/share/nginx/html
leke
Postby duff » Wed Sep 11, 2013 9:43 pm
Hi leke
total 12
-rw-r--r-- 1 root root 537 Sep 24  2012 50x.html
-rw-r--r-- 1 root root 612 Sep 24  2012 index.html
-rw-r--r-- 1 root root  20 Sep 11 17:59 info.php
Following another post from someone using Arch Linux I removed nginx, nginx-common, nginx-full, php5-common, php5-fmp and php5-cli. Reinstalled nginx, nginx-common, nginx-full, php5-common and php5-fmp. Now I can display the info.php page as it should be.
But if I try my own code in html it doesn't display properly. For example:
<!DOCTYPE html>
<html>
   <head>
      <title>Example.com test</title>
   </head>
   <body>
      <p>Success with the virtual server</p>
   <?php
          echo "<p>php says hi</p>";
   </body>
</html>
displays as:
php says hi
i.e. the trailing "; ?> are shown on the page.
So that's strange and annoying enough. If I save the index page as index.php instead of index.html and point my browser at the localhost site (http://locahost:8080) it tries to download the file rather than displaying it.
Thanks for any help/advice.
Best
duff
duff
Postby leke » Thu Sep 12, 2013 4:01 am
Interesting, I've never seen anything like that before, but then I've never used Nginx :P
Does the error log report anything?
leke
Postby duff » Thu Sep 12, 2013 10:14 am
Hi leke
Tracked the problem down to a misconfigured virtual hosts file for the example site. I'd accidentally included a closing curly bracket where there shouldn't have been one.
i.e.
server {
   listen 8080;
   listen [::]:8080 default_server ipv6only=on;
   root /var/www/example.com/public_html;
   server_name localhost; # since I'm only testing here
} # THIS SHOULD NOT BE HERE
   location ~ \.php$ {
   #   # With php5-fpm:
} # THIS IS THE REAL CLOSING BRACKET
Thanks for your input.
Best
Iain
duff
