| What's your preferred pointing device on a laptop ? |
| Trackpad |
0% |
[ 0 ] |
| Mouse |
50% |
[ 3 ] |
| Nipple |
50% |
[ 3 ] |
| Other |
0% |
[ 0 ] |
| Total Votes : 6 |
Nigel LXF regular
Posted: Sun Oct 30, 2005 11:45 pm Post subject: Synaptics touchpad |
Hi Folks,
I'm happily running SuSE 9.2 on my laptop, usually with a USB mouse. The machine also has a Synaptics touchpad which I use when I can't be bothered to plug the mouse in.
However, I'm getting really frustrated with it because it's too sensitive. And I can't stand the "tap to click" function - I keep clicking when I don't want to. And I'm forever brushing it with my palms whilst typing (and it still works even with the USB mouse plugged in).
Under Windows, the Synaptics driver allows you to turn tapping off and to adjust the sensitivity of the touchpad. Is there an equivalent for Linux ? If so, could someone please point me in the right direction ?
Many thanks,
Nigel. |
nelz Moderator
Posted: Mon Oct 31, 2005 12:05 am Post subject: RE: Synaptics touchpad |
There is a way to turn it off, I did so on another laptop. ISTR it was somewhere in xorg.conf.
I don't particularly like trackpads, I much preferred the nipple on my old Thinkpad. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Nigel LXF regular
Posted: Mon Oct 31, 2005 12:14 am Post subject: Re: RE: Synaptics touchpad |
| nelz wrote: | | I don't particularly like trackpads, I much preferred the nipple on my old Thinkpad. |
Toshiba also used to use nipples, 'twas a dark day when they switched to trackpads.
Turning the trackpad off completely on this laptop is a last-ditch solution - I'd really prefer to tune it so I can live with it. That way if I forget to take a USB mouse with me I can still use the laptop. |
Rhakios Moderator
Joined: Thu Apr 07, 2005 12:18 am Posts: 7484 Location: Midlands, UK
Posted: Mon Oct 31, 2005 12:17 am Post subject: RE: Re: RE: Synaptics touchpad |
Indeed, with SuSE9.2 and 9.3 I had to do a lot of fiddling to get my touchpad on my Toshiba laptop to work sensibly. SuSE10 is rather nice in that it has relieved me of the need to do this, it works just fine  _________________ Bye, Rhakios |
Nobber LXF regular
Joined: Mon Apr 11, 2005 4:24 pm Posts: 370 Location: Nova Scotia
Posted: Mon Oct 31, 2005 9:42 am Post subject: RE: Re: RE: Synaptics touchpad |
A few years ago I used tpconfig to turn off the tap-to-click feature on my HP Omnibook's touchpad. It worked fine. _________________ 800 LINES ERIC - GET BACK TO PYSKOOL |
Nigel LXF regular
Posted: Mon Oct 31, 2005 10:13 am Post subject: RE: Re: RE: Synaptics touchpad |
That looks promising... I'll give it a try this evening.
Many thanks  |
nelz Moderator
Posted: Mon Oct 31, 2005 11:38 am Post subject: RE: Re: RE: Synaptics touchpad |
According to http://gentoo-wiki.com/HARDWARE_Synaptics_Touchpad you can disable the tap-to-annoy-you feature by setting MaxTapTime to zero in xorg.conf. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Nigel LXF regular
Posted: Mon Oct 31, 2005 2:45 pm Post subject: RE: Re: RE: Synaptics touchpad |
Even better
Will give this a try when I get home.
Do you know of anyone who actually likes the "tap" feature ?
nelz - am I right in thinking you use an ibook ? What (if anything) do you do about the touchpad on that ? (I'm considering investing in an ibook if I get a decent Xmas bonus this year). |
nelz Moderator
Posted: Mon Oct 31, 2005 4:01 pm Post subject: Re: RE: Re: RE: Synaptics touchpad |
| Nigel wrote: | | Do you know of anyone who actually likes the "tap" feature ? |
Plumbers or dancers?
| Nigel wrote: | | nelz - am I right in thinking you use an ibook ? What (if anything) do you do about the touchpad on that ? (I'm considering investing in an ibook if I get a decent Xmas bonus this year). |
Nothing, I downloaded an xorg.conf from http://www.alessandroronchi.net/wiki/LinuxOnIBookG4 and it just worked. The single mouse button is a bit of a pain, but it is easy enough to map F11/F12 to the middle/right buttons. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Nigel LXF regular
Posted: Mon Oct 31, 2005 4:10 pm Post subject: Re: RE: Re: RE: Synaptics touchpad |
Love the new sig, nelz  |
nelz Moderator
Posted: Mon Oct 31, 2005 4:48 pm Post subject: RE: Re: RE: Re: RE: Synaptics touchpad |
Make the most of it. It's a one day special!  _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
