Disk I/O Error!
Disk I/O Error!
Postby Narendra » Mon Aug 12, 2013 7:08 pm
Hello,
I am calling from the Ubuntu's Live CD. Can not boot my computer it says DISK 0 I/O Error!. What does it mean? and how can it be repaired?
I have 2, 500 Gb Hard Disks on my computer and on the first disk i have installed ubuntu and windows 7 , dual booting, but I can not boot in any of the systems , the message says there is no operating system installed.
Please advise.
Thank you.
Narendra.
Narendra
Narendra
Postby Nuke » Mon Aug 12, 2013 7:29 pm
It means that the BIOS cannot read anything (or anything meaningful) from the Master Boot Record of the first hard drive. It may be that the disc has failed, or that it is physically fine but the contents of the MBR are corrupt.
Have you just installed an OS, or has this error come out of no-where?
You should try a rescue live Distro such as you get on the LXF disk sometimes, or Smart Boot Manager (SBM) which came with (eg) the LXF172 DVD. They should tell you what OS's (if any) are on your various partitions. Depending on results, you should/might then be able to rebuild your MBR.
Nuke
Postby Narendra » Mon Aug 12, 2013 7:53 pm
It appeared out of no where!
I'll try all these tomorrow.
Hope it works!
Narendra.
Narendra
Narendra
Postby nelz » Mon Aug 12, 2013 9:37 pm
You could also try reseating the drive cables, or replacing them if you have spares.
Postby Narendra » Tue Aug 13, 2013 1:58 pm
Thank you for your replies!
Its done!
Seems to be working now.
But can not understand why it happened in the first place. I did reduce the boot time to 5 seconds and swapiness to 10.
Reseated the cables and installed Grub with the boot-repair CD!
Narendra
Narendra
