Mint Problems
Mint Problems
Postby TonyBradley » Mon Aug 05, 2013 9:34 am
Has anyone else had problems using Mint as supplied on the coverdisc?
Earlier versions ran like a dream, but I've not been able to successfully install either Mint 14 or Mint 15.
There seems to be a problem with the display server, as I (eventually) get the following message: "The display server has been shut down 6 times. It's likely that something bad is going on".
Any ideas or suggestion would be gratefully received...
Postby nelz » Mon Aug 05, 2013 10:19 am
Is this when booting from the DVD or after installation?
Have you tried it on a different computer?
Postby heiowge » Mon Aug 05, 2013 8:57 pm
I had exactly the same thing happen with a Mint 15 install from a stick. Turned out to be a faulty stick. A fresh install from a new stick worked a treat.
Perhaps a new disc?
Could anyone link him an iso of the disc? Or you could grab Mint 15 from their site...
