Have to change resolution to fix lag
Postby RyanF109 » Mon Jul 15, 2013 11:39 pm
While playing games on Steam (namely Left 4 Dead 2 and Garry's Mod) they start running absolutely fine and then after a random time the FPS will drop to roughly a constant 15fps permanently and to fix this I have to change resolution from the options menu and change back, and after a random period of time it will happen again.
I am using 310 drivers obtained through the "Additional Drivers" in 12.04. This also happens in Linux Mint.
RyanF109
Re: Have to change resolution to fix lag
Postby darry1966 » Tue Jul 16, 2013 8:27 am
RyanF109 wrote:While playing games on Steam (namely Left 4 Dead 2 and Garry's Mod) they start running absolutely fine and then after a random time the FPS will drop to roughly a constant 15fps permanently and to fix this I have to change resolution from the options menu and change back, and after a random period of time it will happen again.
Can I ask you Ryan to maybe try asking Spatry on Spatry's cup of Linux on Youtube he is an expert on Steam.
O.S. AnitaOS based on Puppy Linux 4.12 Barebones - a distro for retro computers and newer.
darry1966
Postby Ram » Wed Jul 17, 2013 12:39 am
What GFX card you running, I have no issue with my old GTS8800 with CSS, TF2 or Portal, have yet to get L4D or GM.
Postby RyanF109 » Fri Jul 19, 2013 1:52 pm
Ram wrote:What GFX card you running, I have no issue with my old GTS8800 with CSS, TF2 or Portal, have yet to get L4D or GM.
GTX 460
RyanF109
Users browsing this forum: Google [Bot], Yahoo [Bot] and 3 guests
