XP runs out next April
Postby Narendra » Sat Jun 22, 2013 6:55 pm
Hello,
I understand Windows XP runs out next April and there will not any security patches from the Microsoft then on. If I install Xp in VIRTUALBOX as a guest to Ubuntu 13.04, will that be safe? Actually I have that kind of configuration at the moment and do not wish to discard XP. Please advise!
Thank you.
Narendra
Narendra
Postby johnhudson » Sat Jun 22, 2013 8:25 pm
It will be safe after April 2014 if you do not connect to the Internet or allow it to copy from a USB stick.
Postby Dutch_Master » Sat Jun 22, 2013 9:08 pm
johnhudson wrote:It will be safe after April 2014 if you do not connect to the Internet or allow it to copy from a USB stick.
Let me rephrase that: it'll be safe, as long as you take care in what [programs] you put on your (virtual) machine, as well as keeping your malware scanner up-to-date.
Postby heiowge » Sat Jun 22, 2013 9:49 pm
Ermmm.... when EXACTLY was XP considered in any way safe? :lol:
As for it running out in April... again? How long do you think MS will extend its shelf life to this time? :lol:
Postby Dutch_Master » Sat Jun 22, 2013 10:06 pm
XP was safe, on the install-disk ;)
Postby nelz » Sat Jun 22, 2013 10:28 pm
Dutch_Master wrote:Let me rephrase that: it'll be safe, as long as you take care in what [programs] you put on your (virtual) machine, as well as keeping your malware scanner up-to-date.
That's not enough. If an exploit is discovered in an existing program after April, it will not be fixed, but all the script kiddies will now about it.
The easy answer is that come April, you'll have one more reason to not use XP. The fact that it is running in a VM is immaterial.
Postby MartyBartfast » Sun Jun 23, 2013 8:23 am
It largely depends on what you're using XP for, years ago I kept a Windows install for a single program, it didn't need to go on the net, the input files for it were grabbed on my Linux box and put on a shared partition; for that particular case I could now keep a pristine XP VM, blow it away after every use and restore the pristine container every time.
MartyBartfast
Postby roseway » Sun Jun 23, 2013 11:52 am
That's much the same as my situation. The only reason I keep an XP machine at all is to build the Windows versions of programs I develop. I do all the development on a Linux machine, then periodically I transfer the source to the XP machine to build that version. At the moment it has access to the internet, but it doesn't need it.
Eric
roseway
Postby Narendra » Fri Jun 28, 2013 7:19 pm
Thank you very much for your replies!
Is there any distro = XP?
Please advise.
Thank you.
Narendra
Narendra
Postby ajgreeny » Fri Jun 28, 2013 10:20 pm
Narendra wrote:Thank you very much for your replies!
Please advise.
Thank you.
Maybe worth looking at Zorin
http://www.zorin-os.com/
http://mylinuxexplore.blogspot.co.uk/20 ... ne-of.html
http://distrowatch.com/table.php?distribution=zorin
I have not seen or used it personally, so check it out carefully. It was on the LXF 170 dvd, but I'm not sure which version it was.
I have just looked and it was version 6.0.2 Lite.
If it looks interesting you can get version 7 from their website linked above.
ajgreeny
Postby cmcevoy » Sat Jun 29, 2013 9:08 am
Dutch_Master wrote:XP was safe, on the install-disk ;)
You sure?
Sort of depends on your definition of Trojan Horse...
cmcevoy
Postby Narendra » Sat Jun 29, 2013 1:07 pm
I have downloaded and install the Zorin later on.
Please check the link below, if ReactOS is any good.
http://tinyurl.com/7t43s
Thank you.
Narendra
Narendra
Postby M-Saunders » Sat Jun 29, 2013 1:22 pm
Narendra wrote:Please check the link below, if ReactOS is any good.
That's the first time I've seen a TinyURL that's longer than the address to which it points :-)
Anyway, ReactOS is an impressive project given that (AFAIK) nobody is paid to work on it full-time. It can run various older Windows apps, but it's still very much in Alpha stage and not recommended for full-time use.
If you absolutely need to run one or two Windows apps, it's worth a try, and cheaper than a full Windows license.
Of course, WINE is another option...
M
M-Saunders
Postby Narendra » Sat Jun 29, 2013 2:17 pm
Thank you very much for your reply!
I use Ubuntu and its installed with WINE but it does not install Photoshop Elements 11!
And when some programmes installed on WINE can not get uninstalled!
Narendra
Narendra
Postby heiowge » Sat Jun 29, 2013 2:24 pm
Sounds like a lot of Windows apps. Those things go on clean, but don't want to let go when you've had enough! :lol:
Have you tried GIMP instead of photoshop?
