New NAS - Cant mount/see HDD drives [SOLVED]
Postby GeordieJedi » Thu May 30, 2013 10:35 pm
Right, I've managed to SSH into my NAS box
It's running
BusyBox v1.16.1 (2013-04-16 20:15:54 CST) built-in shell (ash)
I've just ran the command that Nelz has stated with the following results
Command =
sudo mount 192.168.x.x:/volume1/video -t nfs /media/video_share
Error msg =
mount.nfs: access denied by server while mounting 192.168.x.x:/volume1/video
I've installed syslog server and tried to take a quick look at the logs themselves
(there is an app on the synology's NAS box itself).
I ran Nelz's command again a couple of times, but I cant find any mention of an attempt
to access the NAS from my client PC (in the logs themsleves).
(And yep, "a fart in a wicker chair" I'm stealing that one :D thanks).
GeordieJedi
Postby Ram » Fri May 31, 2013 12:04 am
Geordie,
That last command was meant to be ran from the client.
Log back on to the NAS via SSH and run these
cat /etc/exports
exportfs
Postby nelz » Fri May 31, 2013 12:33 am
Post the infor Ram asked for then find the system log file in var log on the NAS, probably messages but it might be current or syslog, and run
tail -n 0 -f /var/log/messages
Leave that running and then try to mount the NAS share from another terminal and watch its output. You should see any error messages from the server here.
Postby GeordieJedi » Mon Jun 03, 2013 9:45 pm
Command 01 =
cat /etc/exports
Error message =
cat: can't open '/etc/exports': Permission denied
Command 02 =
exportfs
Error message 02 =
exportfs: could not open /var/lib/nfs/.etab.lock for locking: errno 13 (Permission denied)
I also ran Nelz's command on terminal 1 and then tried to mount command in terminal 2.
Nelz's command =
However I didn't see any output in terminal 1.
But in terminal 3 I also managed to cd into the /var/log/messages dir
and saw the following dir's =
dms.log            log.smbd           messages           partition          synoconn.log
log.nmbd           lvm_lv_create_log  mount.log          pgsql.startup.log  synosys.log
GeordieJedi
Postby nelz » Mon Jun 03, 2013 10:57 pm
Then you want the messages file. Just to be clear, you are tailing the system log file on the NAS (over SSH) but running mount on the client.
Postby GeordieJedi » Tue Jun 04, 2013 8:34 pm
Hi Nelz. Yes that's right. However I've just ran those commands again tonight to double check.
Terminal 0 (SSH'd into my NAS box)
Command =
Result =
The cursor sits there blinking (as if it's doing something in the back ground)
which I suspect it is.
Terminal 1 (Client PC)
Command =
Error message =
GeordieJedi
Postby GeordieJedi » Tue Jun 04, 2013 8:43 pm
I've just taken another look at terminal 0 and some error messages have appeared
(However nothing to do with mounting HDD's though....)
Jun  4 22:35:55 kernel: [ 2246.590000] ata2: wake up from deepsleep, reset link now
Jun  4 22:35:55 kernel: [ 2246.920000] ata2: device plugged sstatus 0x123
Jun  4 22:35:55 kernel: [ 2249.600000] ata2: exception Emask 0x10 SAct 0x0 SErr 0x4010000 action 0xe frozen
Jun  4 22:35:55 kernel: [ 2249.610000] ata2: edma_err_cause=00000010 pp_flags=00000000, dev connect
Jun  4 22:35:55 kernel: [ 2249.610000] ata2: SError: { PHYRdyChg DevExch }
Jun  4 22:36:02 kernel: [ 2255.790000] ata2: link is slow to respond, please be patient (ready=0)[
Also the time on the NAS is 1 hour fast though.
(I don't think that should make any difference).
GeordieJedi
Postby Ram » Tue Jun 04, 2013 9:02 pm
Can you run
ps -ef | grep nfs
On your NAS and post the output back
Postby GeordieJedi » Tue Jun 04, 2013 9:37 pm
HI Ram here's the output from your command
ps: invalid option -- e
BusyBox v1.16.1 (2013-04-16 20:15:54 CST) multi-call binary.
Usage: ps
Report process status
Options:
   w   Wide output
GeordieJedi
Postby Ram » Tue Jun 04, 2013 9:54 pm
GeordieJedi wrote:HI Ram here's the output from your command
Usage: ps
Options:
   w   Wide output
Didn't realize BusyBox had no ps command.
Can you try
 netstat -a | grep nfs
Just trying to work out if nfs is running.
Postby GeordieJedi » Tue Jun 04, 2013 9:56 pm
tcp        0      0 0.0.0.0:nfs             0.0.0.0:*               LISTEN
udp        0      0 0.0.0.0:nfs             0.0.0.0:*
GeordieJedi
Postby Ram » Tue Jun 04, 2013 11:23 pm
GeordieJedi wrote:
Looks like it Listening, good sign.
When you ran
cat /etc/exports
exportfs
Were you root, if not try again has root.
Failing that
 ls -l /etc/ex*
Postby GeordieJedi » Wed Jun 05, 2013 8:49 pm
Hi Ram.
when I run command 01
cat /etc/exports
exportfs
result =
I'm pretty sure I'm root (as I log into the admin account vis SSH).
Command 02 =
 ls -l /etc/ex*
Result =
-rw-------    1 root     root           273 May 12 22:23 /etc/exports
-rw-------    1 root     root           273 May 12 22:23 /etc/exports_map
Additionally whenever I login into the NAS vis SSH I get the following (error ??) message =
Could not chdir to home directory /var/services/homes/admin: No such file or directory
GeordieJedi
Postby nelz » Wed Jun 05, 2013 11:39 pm
You're not root, you'e logging in as a user called "admin". Can you login as root?
ssh root@hostname
Alternatively, can you run the commands with sudo?
Postby GeordieJedi » Sun Jun 09, 2013 7:08 pm
Hi again.
Command =
ssh root@hostname
Result =
/volume1/video   Yavin(rw,async,no_wdelay,no_root_squash,insecure_locks,anonuid=0,anongid=0)
/volume1/photo   Yavin(rw,async,no_wdelay,no_root_squash,insecure_locks,anonuid=0,anongid=0)
/volume1/music   Yavin(rw,async,no_wdelay,no_root_squash,insecure_locks,anonuid=0,anongid=0)
Hoth> exportfs
Command 02 =
exportfs
Result =
(There was not output but it seemed to have worked, as the shell prompt returned
to it's normal position waiting for it's next command).
GeordieJedi
PreviousNext
Users browsing this forum: Google [Bot], Yahoo [Bot] and 0 guests
