Windows issues
Windows issues
Postby heiowge » Tue May 21, 2013 8:56 am
My linux partition boots 99% of the time first time.
For my windows partition, that score is closer to 5%.
Many times it hangs on the black screen with the wobbly windows logo. Only holding in the power button gets it to stop. Windows repair often does nothing. Leaving my windows partition unused for a week seems to fix it sometimes.
Sometimes it just cuts out. Goes from fully working to off in an instant, like I'd pulled out the power cable.
Windows and Linux are on the same hard disk. They are using the same hardware. Windows doesn't work right. Linux does.
Oh, and I have 0 funds to get it fixed. :cry:
Any help?
Postby Ram » Tue May 21, 2013 7:47 pm
Have you tired booting into safe mode ?
Open dos run chkdsk /? depends on version use /f or /r
Postby heiowge » Fri May 24, 2013 3:38 pm
Did that and it ran great. For that occasion. Now it's not working again. :roll:
Linux still works great.
Postby Ram » Fri May 24, 2013 4:15 pm
You got the latest patches, I know MS can leave systems unstable of a patch day Tuesday. What about Video drivers? eta.
Postby heiowge » Fri May 24, 2013 6:13 pm
I don't use any updates on windows 7. I deactivate them entirely during install. :wink:
Postby Ram » Fri May 24, 2013 7:38 pm
heiowge wrote:I don't use any updates on windows 7. I deactivate them entirely during install. :wink:
Maybe you should :wink:
Postby towy71 » Sat May 25, 2013 8:09 am
I'm sure that if I used Windows I would update more regularly than I would anything else, after all MS know how vulnerable their systems are and they do try :roll:
Postby heiowge » Sat May 25, 2013 8:15 am
I'm more concerned about them patching the little error with my activation timer... 8)
