New NAS - Cant mount/see HDD drives [SOLVED]
Postby GeordieJedi » Tue May 14, 2013 11:05 pm
Hi all.
OK, I've finally taken the plunge and gotten a fantastic nice new shiny NAS
(A Synolgy DS413J)
However I'm struggling to get my NAS HDDs mounted and visable on my PC/network.
I've ran through the setup (using Synolgy Disk Station Manager = DSM).
I can connect to the NAS via a web broswer fine.
My main question is this -
1. How do I now get my NAS and it's HDD's to appear/mount/be usable on my network
so that either PC can connect to it and share/swap data and files ?
Do I need to create some mount points in the FSTAB ?
I gave it a try and got the following error messages
command =
root@[PC name]:~/Documents# mount 192.168.x.xx:xxxx/volume1/video /media
error message =
mount: wrong fs type, bad option, bad superblock on 192.168.x.xx:xxxx/volume1/video,
       missing codepage or helper program, or other error
       (for several filesystems (e.g. nfs, cifs) you might
       need a /sbin/mount.<type> helper program)
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
I beleive it's because I left a colon from the end of the IP address ?
I then tried again with the colon and got the following error =
bash: 192.168.x.xx:xxxx:/volume1/video: No such file or directory
Here is one of the lines from my FSTAB relating to my NAS box.
192.168.x.xx:xxxx/volume1/video      ext4   defaults   0   0
Useful info
Ubuntu 12.04
DE = KDE
Virgin media cable modem/router (downstairs)
Cat cable run upstairs to switch (upstairs in office)
PCs and NAS connected to switch (upstairs in office)
Synology DS413J NAS =
2x 3TB HDD's in Synolgys hybrid RAID array (Kinda RAID 1) making a total of
2.68 TB usable space
Any help or advice would be grateful appreciated !
Thanks.
GeordieJedi
Postby nelz » Tue May 14, 2013 11:16 pm
It would be easier if you gave the actual address you are using (it is a private address to your network so there's no risk in exposing it) In particular, is the xxxx a port number? It looks like it but it is not usual to use port numbers with NFS. For example, here is an NFS line from my fstab - using a hostname rather than an IP address, but that shouldn't make a difference.
lunkwill:/mnt/portage  /mnt/portage  nfs  rsize=8192,wsize=8192,soft  0 0
The simple command line equivalent, without the options, is
mount lunkwill:/mnt/portage -t nfs /mnt/portage
Postby GeordieJedi » Wed May 15, 2013 9:38 pm
Hi there nelz.
I've changed the hostname of my NAS now (as it's a lot easier to type).
I've tried a few quick experiments with the FSTAB and I did manage to get some mount points created by adding
this line to the FSTAB file =
Hoth:/volume1/photo /mnt/photo_share/photo nfs nouser,atime,auto,rw,dev,exec,suid 0 0
So the mount points showed up on the mnt dir, but they were owned by root
I then tried a chown to my username but then bash said that the dirs did not exist !
GeordieJedi
Postby nelz » Wed May 15, 2013 10:20 pm
You need to set ownerships after the filesystem is mounted, changing the owner of the mount point does nothing.
Can you SSH into the NAS? What does "exportfs" say.
Postby GeordieJedi » Thu May 16, 2013 9:28 pm
Ok.
command =
exportfs
result =
The program 'exportfs' is currently not installed.  You can install it by typing:
sudo apt-get install nfs-kernel-server
I've read that I "should ?" get a programme called nfs-custom installed too.
Is this useful/necessary to get my NAS working properly ?
Also, i've not tried to SSH into it yet (not entirely sure how to).
Additionally -
When using dolphin to look at my file structure, the NAS shares (kind of show up).
In the sense that they appear in the left pane. But When I click on them I get the error message =
"An error occurred while accessing 'volume1/music on Hoth', the system responded:
mount:only root can mount Hoth:/volume1/music on mnt/music_share/music"
However If I navigate to the root dir then goto the mnt dir
I can actually click and access the NAS share dirs.
(But they are still obviously owned by root and I cant do much
with them).
It seems very strange
GeordieJedi
Postby nelz » Thu May 16, 2013 9:37 pm
If you haven't tried SSH, how did you run exportfs? Or did you run it on the client? I meant to run it on the NAS, it shows how its NFS shares are set up.
Can you mount the shares as root? Only root can mount devices not in /etc/fstab, so you need to add them there and put "users,noauto" in the list of options to allow any user to mount a share on demand. Or leave those options out and let the shares mount when you boot - depending on whether the NAS is always available.
Postby GeordieJedi » Sun May 19, 2013 8:47 pm
I ran exportfs as a bash command on my PC.
I "looks like" I can mount the drives as root.
If I navigate to the mnt dir, I then see the following dirs -
music_share
photo_share
video_share
(these are the names I've given to the three corresponding dirs on the NAS.
I believe you have to give them a different name than dirs on the NAS box itslef ?).
I currently have the following line in my FSTAB =
Hoth:/volume1/video /mnt/video_share/video nfs nouser,atime,auto,rw,dev,exec,suid 0 0
I intend to have the NAS on permanently (once I get this sorted).
So should I change/add the options "users,noauto" in the FSTAB ?
Thanks.
GeordieJedi
Postby nelz » Sun May 19, 2013 8:56 pm
Running exportfs on the PC tells you nothing of relevance.
If you can mount them as root from fstab, then all is fine. Once mounted they worls like normal Linux filesystems so you set permissions with chown and chmod in the usual way, after mounting them.
Postby GeordieJedi » Sun May 19, 2013 9:41 pm
When I use dolphin to navigate the fs,
The NAS shares show up on the left hand pane
(looks like a networked drive icon).
But When I click on them I get the error -
However If I navigate there by clicking on the mnt dir it looks like this -
root>mnt (it shows the following 3 dirs)
music_share
photo_share
video_share
Then If I click onto music share =
root>mnt>music_share
Once I click onto music_share it looks like this
root>mnt>music (as it would appear on the NAS)
If I click on the music dir, things change to this =
/volume1/music on hoth
I tried an experiment, and created a dir called "test" Dolphin let me create the dir.
However If I go into the NAS via the web browser, my test folder doesn't appear in the music dir.
GeordieJedi
Postby nelz » Sun May 19, 2013 9:56 pm
It sounds like the share is not mounted, the directory is still there but the file you create is in the root filesystem, not on the share. What is the output (on the PC) from this?
mount | grep nfs
Postby GeordieJedi » Sun May 19, 2013 10:24 pm
The result is nothing.
The command executes and there is no response and then it returns to the next line.
GeordieJedi
Postby nelz » Sun May 19, 2013 11:38 pm
That means you have no nfs shares mounted.
Postby GeordieJedi » Mon May 20, 2013 9:55 pm
How do I mount my NAS shared folders/HDD's ?
What am I missing to let me do this ?
GeordieJedi
Postby nelz » Mon May 20, 2013 9:57 pm
Suitable lines in /etc/fstab, what to you have in there for the shares?
Postby GeordieJedi » Mon May 20, 2013 10:01 pm
Here's the relevant portion of my fstab =
Hoth:/volume1/music /mnt/music_share/music nfs nouser,atime,auto,rw,dev,exec,suid 0 0
Additionally, do I need the smbfs and nfs-common packages installed ?
GeordieJedi
