Zip files, then delete them.
Postby thusgaard » Wed May 01, 2013 8:14 pm
Hi
I'm running a script that generates a lot of files. But 4000 files in the same directory is a bit much...
So I have added a few lines to my script and currently I have 4173 files in my data directory.
I want to zip/gzip/tar the files in the directory when there are X files or more in the directory. And the delete them. I have the part with when to run the zip+delete job, I even have a simple zip running. But how do I delete the files in the folder that have been added to the zip file.
Bonus info:
the files are .jpg average filesize is less than 200kB
Bonus question:
What is the difference between Zip/Gzip/tar?
J;-)
thusgaard
Postby nelz » Wed May 01, 2013 9:32 pm
If the files have no spaces in their names
FILES=$(ls -1 *.jpg)
tar cf somearchive.tar $FILES
rm -f $FILES
Zip is a DOS/Windows archive format, universal but not particularly good compression. Tar creates uncompressed archives. gzip, bzip2 and xz compress single files or streams and are using in conjunction with tar to produce compressed archives.
However, JPEG files are also compressed and are likely to expand when further compression is attempted, so plain tar is the sensible choice.
Postby nelz » Wed May 01, 2013 10:41 pm
It might be a good idea to make sure the archive is valid before throwing away the original files
tar tf somearchive.tar && rm -f $FILES
Postby Dutch_Master » Wed May 01, 2013 11:48 pm
Are you sure the argument to ls is -1 Nelz? Shouldn't that be -l (letter instead of digit)? (haven't checked the man page, so you could well be right though ;))
Postby nelz » Thu May 02, 2013 12:12 am
Yes, -1. -l would break it horribly.
Postby thusgaard » Thu May 02, 2013 2:11 pm
nelz wrote:It might be a good idea to make sure the archive is valid before throwing away the original files
Works like a charm.
Beauitiful.
Thanks.
thusgaard
