What extras to buy with Raspberry Pi
Postby JohanM » Sun Apr 28, 2013 5:43 pm
When you buy an Raspberry Pi (model B for example), what extras do you need or might come in handy?
    * case (different for model A and B?)
    * power adaptor (or can one use the one for iPod with micro USB cable?)
    * WLAN-stick
    * SDHC memory card
    * HDMI -> DVI adaptor
thanx
JohanM
Re: What extras to buy with Raspberry Pi
Postby dandnsmith » Sun Apr 28, 2013 6:40 pm
JohanM wrote:When you buy an Raspberry Pi (model B for example), what extras do you need or might come in handy?
    * case (different for model A and B?) depends on your desire (I use a VESA plate to screw to monitor)
    * power adaptor (or can one use the one for iPod with micro USB cable?) - yes, but there are a variety of these which also work (I use a Kindle power lead)
    * WLAN-stick - handy if no ethernet
    * SDHC memory card - for OS
    * HDMI -> DVI adaptor - depends on what your monitor needs
Some sources offer starter packages with bits bundled in - eg cpc.co.uk a search will throw some up
Derek
dandnsmith
Postby bobthebob1234 » Sun Apr 28, 2013 6:47 pm
What you (I) need:
  • pi
  • USB Keyboard
  • USB mouse
  • SD card - read pi wiki, not all work, especially cheap brandless one
  • USB micro charger - ipod may work, check voltage and current
Extras you may or may not find helpful
  • USB wifi / network cable (if you have a pi B)
  • USB powered hub - plug in more usb stuff, hdd, etc
  • Some sort of break out board for GPIO pins if you want to play with them - from a simple DIY to pi cobbler to gertboard
  • Battery pack - if you don't have a mains point near by!
  • Assorted electrical components - eg wire, resistors, LEDs, etc
  • Case - make your own or buy one or don't use one. I have 1 in a case and one not in a case. Just be careful who can stick their fingers/toes/paws in/on it :)
really its just what you want to do with it!
http://www.raspberrypi.org/quick-start-guide is a good place to start
http://uk.farnell.com/jsp/bespoke/bespo ... sories.jsp has a pretty diagram :)
bobthebob1234
Postby JohanM » Mon Apr 29, 2013 5:17 pm
Thanks for the tips.
JohanM
