Docking station for Dell latitude D420 notebook
Postby Davido02 » Wed Apr 03, 2013 9:28 pm
Hi, Ive got myself a docking station for the notebook running Puppy. The docking station has a RW DVD. Im wondering how I can get the notebook to recognise the drive when the pc is on the dock??
Davido02
Postby ferrari » Thu Apr 04, 2013 11:57 pm
Does it show up in the device list?
ls -l /dev/sr*
ferrari
Postby Davido02 » Fri Apr 05, 2013 9:16 pm
The output is as follows
# ls -l /dev/sr*
brw-rw---- 1 root cdrom 11, 0 Apr 3 22:29 /dev/sr0
brw-rw---- 1 root cdrom 11, 1 Feb 14 2001 /dev/sr1
brw-rw---- 1 root cdrom 11, 2 Feb 14 2001 /dev/sr2
brw-rw---- 1 root cdrom 11, 3 Feb 14 2001 /dev/sr3
Davido02
Postby ferrari » Sat Apr 06, 2013 5:52 am
Okay, well that output shows 4 device nodes present. How many CD/DVD drive units do you actually have connected? Other hardware devices can present these as well. (For example, some USB storage hardware present themselves as SCSI CDROM devices).
Now, when you have your docking station attached, what software are you running that does not recognise your 'docking station' DVD unit? It might be more a case of tweaking udev to symlink /dev/dvd with the preferred drive to for example.
For reference, I have
ls -l /dev/dvd
lrwxrwxrwx 1 root root 3 Apr  6 14:37 /dev/dvd -> sr0
ferrari
Postby Davido02 » Sun Apr 07, 2013 9:10 am
Theres no additional drives attached or any other things like external mice pen drives etc but I suppose it is possible something like the touchpad or the mouse pointer in the middle of the keyb could be seen as a device.
If I take the notebook off the dock the top line of the four
disappears
So Id imagine there is a it of tweaking needed somewhere?
Thanks
D
Davido02
Postby nelz » Sun Apr 07, 2013 11:05 am
Do you have a /dev/dvd device/symlink? If not, create it for now with
ln -s sr0 /dev/dvd
and see if DVDs now work.
Postby Davido02 » Sun Apr 07, 2013 9:25 pm
Trying to add the symlink gives
ln: failed to create symbolic link ' /dev/DVD': File exists
Could this be to do with the other devices although I have tried adding symlinks with the other three sr* lines and they all exist
Sorry to be a pain!
D
Davido02
Postby nelz » Sun Apr 07, 2013 9:44 pm
So you do have the symlink? Where does it point to?
ls -l /dev/dvd
Postby ferrari » Sun Apr 07, 2013 11:27 pm
Those symlinks are created by udev. The udev rules of interest are located in
/etc/udev/rules.d/70-persistent-cd.rules
It is possible to edit this file to make sure that your preferred DVD device (which is not really persistent) gets sym-linked as you'd like.
ferrari
Postby nelz » Sun Apr 07, 2013 11:33 pm
Yes, but first we need to establish whether the symlink already exists, and which device it points to.
Postby ferrari » Sun Apr 07, 2013 11:56 pm
For sure, as I hinted to a couple of posts ago :)
ferrari
Postby Davido02 » Tue Apr 09, 2013 8:49 pm
Ok sorry I didn't get things right first time round.
The output from ls -l /dev/dvd is
lrwxrwxrwx 1 root root 8 Apr 9 21:15 /dev/dvd -> /dev/sr0
which I think is pointing to the right thing?
I checked in /etc/udev/rules.d but 70-persistent-cd.rules isnt in there. Reading about UDEV I see mention that it should automatically create this file at bootup but it can be generated by hand. However Im now not sure if it should be generating but isnt for some reason and if I do go to create it myself what has to go into it.
So any help on this would be great!
Many thanks again
David
Davido02
Postby nelz » Tue Apr 09, 2013 9:18 pm
The link is already there, you don't need any extra udev rules.
What actually happens when you try to use a DVD in the drive, for example, what does mplayer say when you try to play a video DVD
mplayer dvd://1
Postby ferrari » Wed Apr 10, 2013 2:56 am
As Nelz mentioned already, the required symlink already exists.
FWIW, recent udev versions have done away with the /etc/udev/rules.d/70-persistent-cd.rules, and symlink only the first device detected (via /lib/udev/rules.d/60-cdrom_id.rules).
Returning to your original question
are you referring to notification of DVD media, auto-mounting of data DVDs, or...?
ferrari
Postby Davido02 » Wed Apr 10, 2013 8:35 pm
It would be to mount the drive. For example if a add a pen drive to the system this shows up as SDB1 which I can then click on and see the content of the pen drive.
Rgds
David
Davido02
Users browsing this forum: Google [Bot] and 4 guests
