Ubuntu laptop internet issues
Postby heiowge » Mon Mar 25, 2013 7:09 pm
I've got an old laptop that I've put Ubuntu 12.04 LXF Remix onto (then upgraded to 12.10).
Problem is I have network access via wired and wireless, but no internet.
ping -c 3 followed by the IP for google gives me the expected results. However, if I follow it with www.google.com or www.google.co.uk, I get
ping: unknown host www.google.co.uk
Any ideas? :?
Postby Rhakios » Mon Mar 25, 2013 9:30 pm
Obviously not getting any nameservers by DHCP. Check /etc/resolv.conf if there's nothing in there then that's likely to be your problem.
The network applet (on which ever desktop you have chosen) should enable you to get nameservers via DHCP or set them manually.
Re: Ubuntu laptop internet issues
Postby mediamgl » Mon Mar 25, 2013 9:40 pm
heiowge wrote:Problem is I have network access via wired and wireless, but no internet.
This happens to me when I start the laptop without it being plugged in to a power supply. If I disable networking, then turn it back on, it again connects to my router, but also the internet works. It never does this when plugged in though; it only happens when first booted from battery.
Not a solution, but at least you are not alone. I haven't checked the Ubuntu forums...
mediamgl
Postby Ram » Tue Mar 26, 2013 12:51 am
As Rhakios says DNS issue.
If using Network Manager, have a look at the connection info and see if it lists your IPS Primary / secondary DNS server IPs.
Compare that to your Desktop.
If /etc/resolv.conf is blank on the lappy or doesn't match the desktop, you could copy the file from the desktop to the lappy.
