Shell script problem...
Postby Bazza » Fri Mar 15, 2013 1:33 pm
Hi guys and gals...
I can't find anything relevant from thw WWW...
Bash question:-
Is it possible to open a new Terminal tab or Window and launch a shell script inside this new Terminal from a shell script running in the original Terminal?
Just answer Yes or No...
If it is possible then I will attempt at finding and doing it.
TIA...
73...
Team AMIGA...
Bazza
Postby Dutch_Master » Fri Mar 15, 2013 2:26 pm
Theoretically: yes. In practice you'll need an X11 environment (obviously :P) and some experiments... Perhaps echo the required command to the child terminal in the create command of said terminal. (bit of C++ programming perhaps?)
Postby Ram » Fri Mar 15, 2013 3:14 pm
man screen
DESCRIPTION
Screen is a full-screen window manager that multiplexes a physical ter‐
minal between several processes (typically interactive shells). Each
virtual terminal provides the functions of a DEC VT100 terminal and, in
addition, several control functions from the ISO 6429 (ECMA 48, ANSI
X3.64) and ISO 2022 standards (e.g. insert/delete line and support for
multiple character sets). There is a scrollback history buffer for
each virtual terminal and a copy-and-paste mechanism that allows moving
text regions between windows.
Postby Gordon » Fri Mar 15, 2013 5:33 pm
Yes
xterm -e script_to_run
or
exec xterm -e script_to_run
Gordon
Postby Bazza » Fri Mar 15, 2013 6:00 pm
Thanks guys...
Gordon, many thanks almost exactly what I want except on exiting the child script the xterm terminal closes down. I want it to remain open and manually close it done when I am actually finished with it...
Will pursue it further...
Thanks...
Bazza...
73...
Team AMIGA...
Bazza
Postby johnhudson » Fri Mar 15, 2013 10:26 pm
Maybe too obvious but is there an
exit
anywhere in the programs? Should be
return
Postby Bazza » Sat Mar 16, 2013 12:27 pm
Hi jh...
No need to worry sussed it... ;o)
See other upload...
73...
Team AMIGA...
Bazza
