Cannot mount partitions
Postby skos » Wed Mar 13, 2013 5:55 pm
Postby skos on Mon Mar 11, 2013 1:28 am
I would like to mount all the partitions like the way i do it with windows but i only few of them allow as user to explore and rwx on them.
Here is the output of a script for my partitions
Boot Info Script 0.61 [1 April 2012]
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
in partition 98 for .
=> Grub2 (v1.99) is installed in the MBR of /dev/sdb and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and uses an
embedded config file:
search.fs_uuid d61f661c-65b3-4ed6-acb2-8b9fa28f33d6 root
set prefix=($root)/boot/grub
=> Grub2 (v1.99) is installed in the MBR of /dev/sdc and looks at sector 1 of
sda1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Linux Mint 14 Nadia
Boot files: /boot/grub/grub.cfg /etc/fstab
sdb1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sdb2: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows XP: NTFS
Boot sector info: According to the info in the boot sector, sdb2 starts
at sector 63. But according to the info from fdisk,
sdb2 starts at sector 409600063.
Operating System:
Boot files:
sdb3: __________________________________________________________________________
File system: ntfs
Boot sector info: According to the info in the boot sector, sdb3 starts
sdb3 starts at sector 614400063.
Operating System:
Boot files:
sdb4: __________________________________________________________________________
File system: Extended Partition
Boot sector type: Unknown
Boot sector info:
sdb5: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7: NTFS
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files:
sdc2: __________________________________________________________________________
File system: btrfs
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders, total 156301488 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 2,048 156,301,311 156,299,264 83 Linux
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
/dev/sdb1 2,048 208,824,319 208,822,272 83 Linux
/dev/sdb2 409,600,063 614,400,062 204,800,000 7 NTFS / exFAT / HPFS
/dev/sdb3 614,400,063 976,768,064 362,368,002 7 NTFS / exFAT / HPFS
/dev/sdb4 208,826,366 409,599,999 200,773,634 5 Extended
/dev/sdb5 208,828,416 409,599,999 200,771,584 7 NTFS / exFAT / HPFS
Drive: sdc _____________________________________________________________________
Disk /dev/sdc: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders, total 78165360 sectors
/dev/sdc2 2,000,896 78,163,967 76,163,072 83 Linux
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 2fa7b4a8-9e88-44ce-8812-ff52fc58dd7f ext4 OS1
/dev/sdb1 0f0bbf2c-07f9-4950-ab0e-f8e7c7599df9 ext4
/dev/sdb2 E23AF54F3AF520E9 ntfs PROG_FILES
/dev/sdb3 7C1E19A31E19580A ntfs New Volume
/dev/sdb5 2EBBA3A241140D3E ntfs
/dev/sdc2 76cea449-c3ec-4776-9723-21a040bdfc41 btrfs
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda1 / ext4 (rw)
/dev/sdb2 /media/PROG_FILES fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sdb3 /media/sdb3 fuseblk (ro,noexec,nosuid,nodev,allow_other,default_permissions,blksize=4096)
/dev/sdb5 /media/2EBBA3A241140D3E fuseblk (rw,nosuid,nodev,allow_other,blksize=4096)
/dev/sdc2 /media/76cea449-c3ec-4776-9723-21a040bdfc41 btrfs (rw)
=========================== sda1/boot/grub/grub.cfg: ===========================
THANKS
skos
Postby skos » Fri Mar 15, 2013 7:44 am
none
skos
Postby nelz » Fri Mar 15, 2013 9:03 am
Can you post the output from mount and the contents of /etc/fstab, using code tags to keep them readable.
Postby skos » Fri Mar 15, 2013 7:11 pm
fstab
UUID=0f0bbf2c-07f9-4950-ab0e-f8e7c7599df9 /media/0f0bbf2c-07f9-4950-ab0e-f8e7c7599df9 ext4 users 0 0
UUID=E23AF54F3AF520E9 /media/PROG_FILES ntfs-3g defaults 0 0
UUID=7C1E19A31E19580A /media/New Volume ntfs-3g defaults 0 0
UUID=2EBBA3A241140D3E /media/2EBBA3A241140D3E ntfs-3g defaults 0 0
UUID=76cea449-c3ec-4776-9723-21a040bdfc41 /media/76cea449-c3ec-4776-9723-21a040bdfc41 btrfs defaults 0 0
UUID=2fa7b4a8-9e88-44ce-8812-ff52fc58dd7f / ext4 defaults 0 1
/dev/sdb3 /media/sdb3 ntfs nls=iso8859-1,ro,users,umask=000 0 0
mount
/dev/sda1 on / type ext4 (rw)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
/dev/sdc2 on /media/76cea449-c3ec-4776-9723-21a040bdfc41 type btrfs (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
mint@mint-System-Product-Name ~ $
skos
