touchpad??
Postby Rhakios » Tue Mar 05, 2013 9:20 pm
Did you get to the second sentence in my reply?
Postby nelz » Tue Mar 05, 2013 9:48 pm
Do you really expect 1sf (troll) to understand the concept of sentences when he has never used a punctuation mark?
Postby 1slipperyfish » Tue Mar 05, 2013 10:35 pm
Rhakios wrote:Did you get to the second sentence in my reply?
yeah is that C:\user\paul\var\logs???
STOP PRESS::::::: i don't know if i mentioned it but i got this laptop from my daughter so i could badly wite code/play linux etc and if it went tu all our photos and personal files are on my pc, anyway i have bought a new battery and flashed the bios update and the battery is recognised ta da! so i finally unpluged the psu and hey presto the touchpad works, do i need to strip it down and put a barrier under the touchpad or do i need to wear and anti-stat band when it's plugged in???
paul
1slipperyfish
Forum Jester
Postby Rhakios » Tue Mar 05, 2013 11:14 pm
Just make sure you flop up onto dry land, being a wet fish, you should be well earthed enough not to need the band on your fin.
Postby 1slipperyfish » Tue Mar 05, 2013 11:18 pm
thanks for that :roll: ive a good mind to start my stalking regime again :twisted:
paul
1slipperyfish
Forum Jester
Postby nelz » Tue Mar 05, 2013 11:58 pm
1slipperyfish (troll) (troll) wrote:i don't know if i mentioned it but i got this laptop from my daughter so i could badly wite code
You don't need another computer to wite badly...
Postby 1slipperyfish » Wed Mar 06, 2013 6:57 am
anyway i've plugged the charger back in and the touchpad is dodgy again??
1slipperyfish
Forum Jester
Postby Rhakios » Wed Mar 06, 2013 7:19 pm
Sounds like an internal short or bad earth from the power connector. Try wetting your hand, standing in a bucket of water and touching any metal bits of the laptop while it's plugged in. If you get fried, you'll know that's the problem. :D
Postby 1slipperyfish » Wed Mar 06, 2013 7:32 pm
:shock: :shock: :shock: :shock: :shock: :shock: :shock:
1slipperyfish
Forum Jester
Postby lok1950 » Wed Mar 06, 2013 11:05 pm
So now you know just don't use the lappy with power supply just use it to charge the batteries besides it's better to drain them before recharge anyway.Good luck with it paul.
Enjoy the Choice :)
lok1950
