Temperature Sensor locations
Postby bobthebob1234 » Tue Jan 29, 2013 11:09 pm
So after much bashing I have managed to get cacti graphing temperature for the machine it is running on from the output of sensors
However I to have better labels than temp1, temp2, temp3 ....
So how do I work out where they are located? Guessing need to know motherboard?
Output of sensors:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
ERROR: Can't get value of subfeature temp1_input: Can't read
Core 0:       +0.0°C  (crit = +100.0°C)
coretemp-isa-0002
Core 1:       +0.0°C  (crit = +100.0°C)
w83627dhg-isa-0290
Vcore:       +1.20 V  (min =  +0.00 V, max =  +1.74 V)
in1:         +1.62 V  (min =  +1.54 V, max =  +1.96 V)
AVCC:        +3.39 V  (min =  +2.98 V, max =  +3.63 V)
in4:         +1.87 V  (min =  +2.04 V, max =  +1.11 V)   ALARM
in5:         +1.21 V  (min =  +1.74 V, max =  +1.02 V)   ALARM
in6:         +1.57 V  (min =  +1.44 V, max =  +2.04 V)
3VSB:        +3.39 V  (min =  +2.98 V, max =  +3.63 V)
Vbat:        +3.34 V  (min =  +2.70 V, max =  +3.30 V)   ALARM
fan1:       2343 RPM  (min =  534 RPM, div = 32)
fan2:          0 RPM  (min =  198 RPM, div = 128)  ALARM
fan3:          0 RPM  (min =    0 RPM, div = 128)
fan4:          0 RPM  (min = 10546 RPM, div = 128)  ALARM
fan5:          0 RPM  (min =    0 RPM, div = 128)
temp1:       +32.0°C  (high = +127.0°C, hyst = -67.0°C)  sensor = diode
temp2:       +25.0°C  (high = +80.0°C, hyst = +75.0°C)  sensor = diode
temp3:       +26.0°C  (high = +80.0°C, hyst = +75.0°C)  sensor = diode
cpu0_vid:   +2.050 V
Its the last 3 temperature readings I am graphing. I can't get the "Adapter: ISA adapter" ones to work (its an intel mobo)
So any ideas how I would go about locating them? (also I don't have physical access to the machine at the moment...)
Cheers
bobthebob1234
Postby roseway » Wed Jan 30, 2013 7:35 am
If you run the command sensors from the command line you'll see more information about the sensors, which may help.
Eric
roseway
Postby Rhakios » Wed Jan 30, 2013 7:35 pm
roseway wrote:If you run the command sensors from the command line you'll see more information about the sensors, which may help.
Looks to me like that is exactly what btb did do. :?
Postby roseway » Thu Jan 31, 2013 7:21 am
Rhakios wrote:Looks to me like that is exactly what btb did do. :?
You're right. I'm an idiot. :oops:
Eric
roseway
