Terminal Strangeness...
Postby heiowge » Thu Jan 24, 2013 6:57 pm
bash: /usr/bin/mint-fortune: No such file or directory
******@******-desktop ~ $ sudo bash
[sudo] password for ******:
******-desktop ~ #
Any ideas...? The only thing I did recently was strip out a buttload of KDE games... :?
Postby xenopeek » Thu Jan 24, 2013 7:34 pm
That can happen if you removed some dependencies (like cowsay, fortune, fortunes-husse, or their dependencies), but that wouldn't be good. /usr/bin/mint-fortune comes from the mintsystem package, which has some adjustments you want on Linux Mint I gather. So I'd install the mintsystem package again if I was you.
Linux Mint 14 Nadia / 64-bit / Cinnamon
xenopeek
Postby MartyBartfast » Thu Jan 24, 2013 7:43 pm
isn't mint-fortune the thing that prints out a pointless (IMHO) little fortune cookie type message? If so and it's the only problem you're seeing then I would be inclined to
 sudo touch /usr/bin/mint-fortune && sudo chmod a+x /usr/bin/mint-fortune
however as xenopeke says it may be a symptom of other problems.
MartyBartfast
Postby xenopeek » Fri Jan 25, 2013 9:27 am
mintsystem does more, but you may have also uninstalled other packages. Upon further thought, I'd recommend you reinstall the package mint-meta-kde to ensure your Linux Mint KDE is complete.
xenopeek
Postby heiowge » Fri Jan 25, 2013 7:04 pm
I did a sudo apt-get install mintsystem (seems to have fixed the weirdness), and am currently doing the mint-meta-kde just to be sure.
Cheers
Postby ajgreeny » Fri Jan 25, 2013 8:36 pm
If it's just those blasted fortune-cookies in terminal that you want rid of, you can easily do it by commenting out the line in the hidden .bashrc file.
I can't remember if it is your user's .bashrc or root's .bashrc, but it is in one or the other, or maybe both.
ajgreeny
