Mint 14 MATE error on startup (SOLVED)
PostPosted: Tue Jan 15, 2013 10:33 am    Post subject: Mint 14 MATE error on startup (SOLVED) Reply with quote
Mint 14 MATE works. Works fine, except for one thing... I get an error message on startup:
language en_GB does not exist using system default
I click past this and it works.
Anyone know how to sort this error?
Ta
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
xenopeek
PostPosted: Tue Jan 15, 2013 2:25 pm    Post subject: Reply with quote
Possibly. What is the output of the following command?
Code:
locale -a
Linux Mint 14 Nadia / 64-bit / Cinnamon
PostPosted: Wed Jan 16, 2013 10:05 am    Post subject: Reply with quote
Code:
locale -a
C
C.UTF-8
en_AG
en_AG.utf8
en_AU.utf8
en_BW.utf8
en_CA.utf8
en_DK.utf8
en_GB.utf8
en_HK.utf8
en_IE.utf8
en_IN
en_IN.utf8
en_NG
en_NG.utf8
en_NZ.utf8
en_PH.utf8
en_SG.utf8
en_US.utf8
en_ZA.utf8
en_ZM
en_ZM.utf8
en_ZW.utf8
POSIX
zh_CN.utf8
zh_SG.utf8
xenopeek
PostPosted: Wed Jan 16, 2013 11:14 am    Post subject: Reply with quote
So it looks like en_GB is supported; I hope it's not a case sensitive thing... Can you take a screenshot of the message when you get it? Share it on tinypic.com or similar free image host.
PostPosted: Wed Jan 16, 2013 11:03 pm    Post subject: Reply with quote
I meant to, but my camera needs charging. I thought about that, so I looked. I've corrected the spelling to include correct case en_GB instead of en_gb.
xenopeek
PostPosted: Thu Jan 17, 2013 8:37 am    Post subject: Reply with quote
Oh, you get this at the boot screen? I assumed it would be after logging in (in that case, just press the Print Screen button to get a screenshot).
PostPosted: Thu Jan 17, 2013 9:18 am    Post subject: Reply with quote
The screen pops up just before I get a desktop. It might be too early to screenshot, but I'll give it a go...
PostPosted: Thu Jan 17, 2013 9:27 am    Post subject: Reply with quote
Screenshot didn't take. Try this:
xenopeek
PostPosted: Thu Jan 17, 2013 10:49 am    Post subject: Reply with quote
Right, but is this before, at or after the login screen Smile
PostPosted: Thu Jan 17, 2013 2:45 pm    Post subject: Reply with quote
There's no login screen. Login is automatic.
xenopeek
PostPosted: Thu Jan 17, 2013 4:28 pm    Post subject: Reply with quote
Okay, found it I think. Edit your /etc/default/locale file as root (gksudo pluma /etc/default/locale). The first line is probably:
Code:
LANG="en_GB.UTF-8"
If there isn't a line that sets LANGUAGE also, add it as follows. If there is, but doesn't have the .UTF-8 bit then add that. It should be set the same as your LANG variable.
Code:
LANGUAGE="en_GB.UTF-8"
Then reboot to activate.
Found through an old bug report on GDM, on which MDM is based that Linux Mint uses. Here: https://bugs.launchpad.net/ubuntu/+source/gdm/+bug/185947. Comments #15 and further were the helpful ones.
PostPosted: Thu Jan 17, 2013 9:23 pm    Post subject: Reply with quote
Made the change to the second line. It previously read "...GB:en" on the end.
No luck though. I got the same error on startup.
That link appears to be dead. It went to another error screen. Crying or Very sad
xenopeek
PostPosted: Thu Jan 17, 2013 11:14 pm    Post subject: Reply with quote
Yeah, sorry. I didn't put the URL in tags and so the dot at the end got included when you clicked on it. Fixed it above. I'm not sure what else could be the cause of this.
PostPosted: Fri Jan 18, 2013 9:48 am    Post subject: Reply with quote
Fixed it!!! Very Happy
I had a look around the MATE section of the Mint forums.
It seems that if I log out and then change the default language to English (GB) in the login screen, the session confirms the default change and then doesn't have the error again.
I just wish they'd build it into the install...
