graemecollin
Posted: Mon Jan 14, 2013 8:26 pm Post subject: New Windows 8 Laptop & Linux Install |
Just picked up a new laptop, with Windows 8 pre-installed. Obviously, this has to go, in favour of something more Linux-flavoured. However, I want to retain a fallback route, if necessary.
Is it possible to generate the OS install disks (not recovery disks that are going to be relying on asubsequently non-existant recovery partition) and without accepting the EULA? If so, how? Obviously, I'm trying to avoid having to go anywhere Win8 to do anything.
Another potential option I can see would be to take an image of the disk, including all partitions, as it stands right now? Kinda like ghosting the drive (albeit onto a significantly smaller drive - I only need the data, not the free space backing up). Is there a Linux distro, that I can boot from CD/DVD/flash-drive that can do this for me?
Many thanks.
-Graeme. |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3358 Location: Birmingham, UK
Posted: Mon Jan 14, 2013 9:24 pm Post subject: |
http://partedmagic.com
Should have all the tools you need.
However the UEFI BIOS might make it less than straightforward. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
johnhudson LXF regular
Posted: Mon Jan 14, 2013 9:31 pm Post subject: |
Your problem is the UEFI BIOS; a lot depends on whether the OEM has let you have the key to enable even to run a Live CD to do anything let alone install Linux.
Maybe worth trying a distro that comes with a solution to the UEFI BIOS - I believe Ubuntu is supposed to. |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7994 Location: Warrington, UK
Posted: Tue Jan 15, 2013 10:55 am Post subject: |
You can turn secure boot off, I had to to boot my new Win8 laptop from a live disk.
I just backed up the whole drive with dd
| Code: | | dd if=/dev/sda bs=1g | gzip >/external/drive/sda.img.gz |
_________________ Unix is user-friendly. It's just very selective about who it's friends are. |
