Another bit of info...
Postby Bazza » Sun Jan 13, 2013 4:30 pm
Hi guys and gals...
I would like another piece of info from all who wish to participate...
1) From your Linux desktop open up a terminal of your choice.
2) Shift this default terminal window to as close to the upper left hand corner as it will go on your desktop.
3) From the prompt type:
****$ printf "\x1B[8;200;300t"<CR>
4) Also type:-
****$ stty size<CR>
And let me have your two values...
5) Close down your terminal...
On this MBP they are 46 and 179.
TIA...
73...
Team AMIGA...
Bazza
Postby purplepenguin » Sun Jan 13, 2013 4:41 pm
lee@mainpc:~$ printf "\x1B[8;200;300t"
lee@mainpc:~$ stty size
55 207
purplepenguin
Postby guy » Sun Jan 13, 2013 4:47 pm
26 112
Postby MartyBartfast » Sun Jan 13, 2013 5:27 pm
200 300
and yes it is a huge terminal that's gone beyond the bounds of the screen.
MartyBartfast
Postby Bazza » Sun Jan 13, 2013 5:56 pm
Hi guys...
Thanks for trying...
You guys who take the plunge to do little snippets like this for me are effectively doing beta testing for my projects.
I find out lots about different shells and never take anything for granted.
1) purplepenguine: your values were what I expected...
2) guy: I am assuming you're running something like a netbook?
3) MBF: Yours has told me NOT to use the Esc sequence to maximise so everything now centres around the standard 80 x 24 or 80 x 25 sizes... I will probably use it just to get one extra line to 80 x 25...
Thanks guys...
73...
Team AMIGA...
Bazza
Postby roseway » Sun Jan 13, 2013 7:06 pm
One more for you:
eric@chaffinch:~$ printf "\x1B[8;200;300t"
eric@chaffinch:~$ stty size
28 136
eric@chaffinch:~$
Eric
roseway
Postby johnhudson » Sun Jan 13, 2013 9:57 pm
36 126
With KDE konsole in full screen mode - just happened to be how I left it.
Postby nelz » Sun Jan 13, 2013 11:04 pm
Using Konsole here, the window size did not change but the contents scrolled up several pages leaving me with a blank prompt. The output was 200 300. I needed reset to make the terminal usable again.
Postby Nuke » Mon Jan 14, 2013 10:30 am
Using Konsole on Mepis, almost same as Nelz got. After the first command, the cursor ended up several blank screens below the prompt, indented as if the prompt was there but invisible. Anything I typed was echoed back at the prompt (if I scrolled back to check) but the focus would fly back to the cursor position, which moved as you typed but its area remained blank. The window did not change size or anything.
The output was :- 300 200 (NOT 200 300).
Nuke
Postby Bazza » Mon Jan 14, 2013 2:02 pm
Hi RW, JH, nelz and Nuke...
I was aware of any pitfalls but did not expect so many from I think seven replies. Looks like my project will have to stay inside a standard 80 x 24 window...
Thanks to all for taking part and doing _risky_ things for me but I never assume that anything is universal and this little snippet is not...
Once again all thanks and this thread can now be closed...
73...
Team AMIGA...
Bazza
Postby guy » Tue Jan 15, 2013 9:10 am
Bazza wrote:2) guy: I am assuming you're running something like a netbook?
Nope. Just an ancient LCD monitor I bought years ago - shop-soiled packaging but high quality Dell model of the day: 1024 x 768 or not much better, I can't recall exactly. The PC is a bit newer - a basic homebuild, nothing special. The sort of cheapskate system that only Linux can breathe life into in today's world.
Postby Ram » Tue Jan 15, 2013 9:43 am
For what its worth my figures are
55 206
But was not quite max size, maxing it I got size of 55 207
Now if I dragged the terminal off the left hand a touch I got a huge terminal of 200 * 300
