Brother printer problem
Postby pk_fox » Mon Jan 07, 2013 1:51 pm
Hi all, my Brother HL-2270DW printer has just stopped printing via my Linux Fedora laptop, the jobs section of the web interface is showing all my jobs as completed but nothing comes out of the printer. I'm running Fedora 17 and haven't used the printer for a couple of months in which time I've had several updates via yum - any ideas ? checked all the usual things paper, cable connected ok etc... The CUPS web interface is not showing any errors either :-( Googled like mad but can't find an answer
pk_fox
Postby Dutch_Master » Mon Jan 07, 2013 2:03 pm
Brother has excellent Linux support, try re-installing the correct driver:
http://welcome.solutions.brother.com/bs ... index.html
Postby pk_fox » Mon Jan 07, 2013 2:17 pm
Dutch_Master wrote:Brother has excellent Linux support, try re-installing the correct driver:
Hi I've tried that - lots of nothing happened - as I said the CUPS web interface is reporting all my jobs as completed and there's plenty of paper - I can ping it - stumped here as it was fine last time I used it. One thing I noticed is if I try to print a test page I get a "/usr/lib/cups/filter/bannertops failed" failed message
pk_fox
Postby Dutch_Master » Mon Jan 07, 2013 2:37 pm
Purge CUPS and re-install that then. Otherwise, try a later version from the CUPS people (not the version in your distro's repo)
Postby pk_fox » Mon Jan 07, 2013 3:06 pm
Dutch_Master wrote:Purge CUPS and re-install that then. Otherwise, try a later version from the CUPS people (not the version in your distro's repo)
Hi thanks for your help, how do I purge CUPS ?
pk_fox
Postby Dutch_Master » Tue Jan 08, 2013 12:58 am
Via yum. Search for the CUPS package then mark it for complete removal.
Postby pk_fox » Tue Jan 08, 2013 8:47 am
Dutch_Master wrote:Via yum. Search for the CUPS package then mark it for complete removal.
Hi, I've removed and reinstalled CUPS but things are still broken - it must be a Fedora thing
EDIT
Have found some info on Google it seems quite a few people are having problems similar to mine ( no jokes please ) and seem to think it's a CUPS issue ( which would make sense )
pk_fox
Postby ferrari » Thu Jan 10, 2013 8:39 am
Is your issue with all print jobs, or just printing pdf-related printing (including browser printing)? There was a similar issue reported in the openSUSE Forums recently as a result of a regression with CUPS and poppler. This will affect other distros too:
https://forums.opensuse.org/english/get ... owser.html
Here's the bug report:
https://bugzilla.novell.com/show_bug.cgi?id=795582
ferrari
Postby pk_fox » Thu Jan 10, 2013 10:21 am
ferrari wrote:Is your issue with all print jobs, or just printing pdf-related printing (including browser printing)? There was a similar issue reported in the openSUSE Forums recently as a result of a regression with CUPS and poppler. This will affect other distros too:
Hi there, my problem is I can't print anything not even a test page, as I stated earlier the printer was working perfectly until recently, then I updated Fedora a couple of times via yum and now I can't print, I can ping the printer and access its web control panel it just will not print - if I connect it to a Windows PC it works perfectly so I know its not the printer - very strange
pk_fox
Postby nelz » Thu Jan 10, 2013 12:23 pm
Anything useful in /var/log/cups?
Postby ferrari » Thu Jan 10, 2013 7:20 pm
Are you connected via USB or ethernet? Please post your printer config from /etc/cups/printers.conf, and maybe a good idea to confirm that you still have the Brother driver packages present
# rpm -qa|grep 2270
ferrari
Postby ferrari » Thu Jan 10, 2013 7:34 pm
If you need to, the verbosity of the CUPS log can be increased by editing the 'LogLevel' directive in /etc/cups/cupsd.conf from 'warn' or 'info' to 'debug' like this
LogLevel debug
The log of interest is /var/log/cups/error_log
ferrari
