Brother printer problem
pk_fox
PostPosted: Mon Jan 07, 2013 1:51 pm    Post subject: Brother printer problem Reply with quote
Hi all, my Brother HL-2270DW printer has just stopped printing via my Linux Fedora laptop, the jobs section of the web interface is showing all my jobs as completed but nothing comes out of the printer. I'm running Fedora 17 and haven't used the printer for a couple of months in which time I've had several updates via yum - any ideas ? checked all the usual things paper, cable connected ok etc... The CUPS web interface is not showing any errors either Sad Googled like mad but can't find an answer
PostPosted: Mon Jan 07, 2013 2:03 pm    Post subject: Reply with quote
Brother has excellent Linux support, try re-installing the correct driver:
http://welcome.solutions.brother.com/bsc/public_s/id/linux/en/index.html
pk_fox
PostPosted: Mon Jan 07, 2013 2:17 pm    Post subject: Reply with quote
Hi I've tried that - lots of nothing happened - as I said the CUPS web interface is reporting all my jobs as completed and there's plenty of paper - I can ping it - stumped here as it was fine last time I used it. One thing I noticed is if I try to print a test page I get a "/usr/lib/cups/filter/bannertops failed" failed message
PostPosted: Mon Jan 07, 2013 2:37 pm    Post subject: Reply with quote
Purge CUPS and re-install that then. Otherwise, try a later version from the CUPS people (not the version in your distro's repo)
pk_fox
PostPosted: Mon Jan 07, 2013 3:06 pm    Post subject: Reply with quote
Hi thanks for your help, how do I purge CUPS ?
PostPosted: Tue Jan 08, 2013 12:58 am    Post subject: Reply with quote
Via yum. Search for the CUPS package then mark it for complete removal.
pk_fox
PostPosted: Tue Jan 08, 2013 8:47 am    Post subject: Reply with quote
Hi, I've removed and reinstalled CUPS but things are still broken - it must be a Fedora thing
EDIT
Have found some info on Google it seems quite a few people are having problems similar to mine ( no jokes please ) and seem to think it's a CUPS issue ( which would make sense )
ferrari
PostPosted: Thu Jan 10, 2013 8:39 am    Post subject: Reply with quote
Is your issue with all print jobs, or just printing pdf-related printing (including browser printing)? There was a similar issue reported in the openSUSE Forums recently as a result of a regression with CUPS and poppler. This will affect other distros too:
https://forums.opensuse.org/english/get-technical-help-here/applications/481656-usr-lib-cups-filter-pdftops-failed-webbrowser.html
Here's the bug report:
https://bugzilla.novell.com/show_bug.cgi?id=795582
pk_fox
PostPosted: Thu Jan 10, 2013 10:21 am    Post subject: Reply with quote
Hi there, my problem is I can't print anything not even a test page, as I stated earlier the printer was working perfectly until recently, then I updated Fedora a couple of times via yum and now I can't print, I can ping the printer and access its web control panel it just will not print - if I connect it to a Windows PC it works perfectly so I know its not the printer - very strange
PostPosted: Thu Jan 10, 2013 12:23 pm    Post subject: Reply with quote
Anything useful in /var/log/cups?
ferrari
PostPosted: Thu Jan 10, 2013 7:20 pm    Post subject: Reply with quote
Are you connected via USB or ethernet? Please post your printer config from /etc/cups/printers.conf, and maybe a good idea to confirm that you still have the Brother driver packages present
Code:
# rpm -qa|grep 2270
ferrari
PostPosted: Thu Jan 10, 2013 7:34 pm    Post subject: Reply with quote
If you need to, the verbosity of the CUPS log can be increased by editing the 'LogLevel' directive in /etc/cups/cupsd.conf from 'warn' or 'info' to 'debug' like this
Code:
LogLevel debug
The log of interest is /var/log/cups/error_log
