Help I've borked the wifes windows box
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS
PostPosted: Tue Dec 11, 2012 11:46 am    Post subject: Help I've borked the wifes windows box Reply with quote
I've made a mistake. Embarassed
My wife wanted some christmas tunes off my pc. I thought I'd transfer them over the network. It could see my pc, the folder with music, and the subfolder with christmas music. Even the music itself.
But would it copy it? No. So I looked online for a solution. One of the folders I needed to look at was hidden, so I ticked the "show hidden files/folders" thingy.
Then it spent 3 mins applying it to subfolders etc. I thought it was windows being slow. Now I find it's doing far more insidious things.
Users folder is missing. The show hidden option is missing. All her music and files are missing. Mad
I booted into a copy of MINT MATE 32 bit that I had on a stick and there it is. Everything is exactly where it should be. I just can't see it in windows. So I'm backing it up to the external drive.
Without doing a full reinstall, any idea how to restore the status quo?
Ta
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
PostPosted: Tue Dec 11, 2012 12:36 pm    Post subject: Reply with quote
where did you get your info from.
Dumb question - have you tried starting it in safe mode ?
PostPosted: Tue Dec 11, 2012 12:42 pm    Post subject: Reply with quote
youtube. Laughing And no.
PostPosted: Tue Dec 11, 2012 1:10 pm    Post subject: Reply with quote
The nightmare continues...
I've got most of it back. For some reason, everthing was set as read only and hidden. And the "apply to sub folders and files" wasn't working that well!
Now it's firefox thats playing up. Windows says it's running and I need to close it down. Only it's not running. Not even a firefox process. Nothing. Even a reinstall of FF doesn't help. Grrr...
PostPosted: Tue Dec 11, 2012 1:18 pm    Post subject: Reply with quote
That probably from the options you've been play with... probably applies to FF too.
Locate FF in the user profile and check it permissions and viability.
PostPosted: Tue Dec 11, 2012 1:52 pm    Post subject: Reply with quote
Yeah, I'm on that atm. Just waiting for the wife to finish playing her facebook games (using chrome). Rolling Eyes
PostPosted: Tue Dec 11, 2012 2:19 pm    Post subject: Reply with quote
Done. I searched for %APPDATA%\Mozilla\Firefox\Profiles\ and then selected all and changed them to not being hidden. Problem solved.
Begs the question though... how much more damaged did windows do by me simply asking it to show me hidden folders?
I am so happy I don't use windoze. Laughing
PostPosted: Tue Dec 11, 2012 4:31 pm    Post subject: Reply with quote
It shouldn't have done anything, done it loads of times without issue.
I'd give it a good seeing to with malware / virus scanners.
PostPosted: Tue Dec 11, 2012 7:15 pm    Post subject: Reply with quote
Recommended: http://www.sysresccd.org/SystemRescueCd_Homepage
Post new topic   Reply to topic    Linux Format forums Forum Index -> Other OS All times are GMT
