Crunchbang Swap partitioning
Postby heiowge » Sun Sep 16, 2012 9:06 pm
Installing Crunchbang (latest pro build) in virtualbox. I set 11.4ish GB for the virtual hd. Guided partitioning doesn't give me much in the way of / or swap, instead blowing most on /home. Since I'm not intending to store many files on it, I wanted a different split.
I intended to give about 8GB to /, and 1GB to Swap with the rest to /home. Alls well and good, except the flipping partitioner doesn't seem to give me an option to set a partition as Swap.
Am I just being dense here?
Here's a screenshot of what I see...
Postby Ram » Sun Sep 16, 2012 10:05 pm
Is it not under 'Enter manually'
Postby heiowge » Sun Sep 16, 2012 10:14 pm
I tried that, but it didn't take "swap" as a correct answer.
Postby Dutch_Master » Sun Sep 16, 2012 11:44 pm
Choose the "do not mount" option, install as per instructions then have gparted mark it as swap. Enter entry in /etc/fstab, save and reboot. :)
Postby nelz » Mon Sep 17, 2012 7:46 am
Do it manually, you don't even need gparted, just "mksawp /dev/sdX", then add it to fstab.
Postby ajgreeny » Mon Sep 17, 2012 10:32 am
Swap is not mounted in the normal way as your root and home partitions are. The line needed in fstab will be
UUID=1bfd912d-b6b6-4a68-9aaf-4139513772ec none            swap    sw              0       0
but with your own UUID, of course.
Just make the partition, then do what nelz said and all should work.
ajgreeny
Postby nelz » Mon Sep 17, 2012 11:16 am
You don't need to use ugly and unreadable UUIDs of course, you could use the plain device name, /dev/sdN, or you could give the swap filesystem a label and use that.
mkswap --label myswap /dev/sdN
and
LABEL=myswap   none   swap   sw   0 0
Postby nelz » Mon Sep 17, 2012 12:10 pm
Which Crunchbang ISO are you using? I've tried crunchbang-10-20120207-i386.bpo.iso and crunchbang-11-20120806-amd64.iso and both gave a graphical installer with a swap option. The Crunchbang 10 ISO also had a text install option, as in your screenshot, but this also allowed swap partitions to be created.
Postby heiowge » Thu Nov 08, 2012 3:00 pm
For those who want to know, this one made the star question in this month's mag! :D
Postby Ram » Thu Nov 08, 2012 4:12 pm
heiowge wrote:For those who want to know, this one made the star question in this month's mag! :D
I didn't as I saw it :D
Got my free stuff through
Postby heiowge » Mon Dec 10, 2012 3:39 pm
My glittering prizes arrived, along with some cool badges! Cheers guys.
PS. It arrived this morning just fine despite getting my road wrong in the address. :lol:
Postby Ram » Mon Dec 10, 2012 6:18 pm
Luck so n so, enjoy.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 7 guests
