Cinnamon panel has gone weird [SOLVED]
PostPosted: Mon Dec 03, 2012 10:10 am    Post subject: Cinnamon panel has gone weird [SOLVED] Reply with quote
Last session I did an update and changed the theme. That's it. Oh, and checked Google+, but I don't think that could cause this:
As you can see, the left side of my panel is fine, but the right hand side has resized all my icons and made some disappear off the screen!
Any ideas / help?
Ta
Oh, and I tried changing the theme back. No change. I also tried rebooting.
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
bobthebob1234
PostPosted: Mon Dec 03, 2012 1:28 pm    Post subject: Reply with quote
Sorry, just want to say
WHERE DID YOU GET YOUR WALLPAPER!!!? I WANT IT!
also have no idea what is wrong with your icons?
Change icon theme then change back?
PostPosted: Mon Dec 03, 2012 2:18 pm    Post subject: Reply with quote
I downloaded a wallpaper for "Dumb ways to die", but it didn't have the psycho killer (bottom right).
Screenshot + original wallpaper + GIMP = Win.
I'll post a link to it as full size as I can when I'm next on that PC (I'm on windows box atm). Sad
PostPosted: Mon Dec 03, 2012 7:39 pm    Post subject: Reply with quote
http://i18.photobucket.com/albums/b119/heiowge/dumbwaystodie.png
That's what I use. Hope it helps.
PostPosted: Mon Dec 03, 2012 9:02 pm    Post subject: Reply with quote
http://postimage.org/image/pyqyh1xp1/
Looks like it's a known bug in Cinnamon...
PostPosted: Mon Dec 03, 2012 9:07 pm    Post subject: Reply with quote
There was a fix included in the post. In case anyone else has this issue, I did this:
Go to Cinnamon Settings > Panel
Check the boxes:
"Use customized panel size (otherwise it's defined by the theme)" and
"Allow Cinnamon to scale panel text and icons according to the panel heights"
