Just had a thought...
Goto page 1, 2  Next
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic
Bazza
PostPosted: Wed Nov 21, 2012 6:14 pm    Post subject: Just had a thought... Reply with quote
Does deleting all the spammers from the database cause memory leaks and/or memory fragmentation and would this be a method of attempting to cause a system crash?
Just a thought...
73...
Team AMIGA...
bobthebob1234
PostPosted: Wed Nov 21, 2012 6:59 pm    Post subject: Reply with quote
Why would deleting things cause cause memory leaks and/or memory fragmentation?? Shocked
PHPBB usually runs on PHP&MySQL, last time I checked deleting things from MySQL doesn't cause memory leaks...
Updating and deleting lots can cause a little overhead on the MySQL tables, but that is very quick and easy to get rid of...
PostPosted: Wed Nov 21, 2012 7:21 pm    Post subject: Reply with quote
Also, this is a very small number of transactions, each one has to be done manually.
Bazza
PostPosted: Fri Nov 23, 2012 6:47 pm    Post subject: Reply with quote
Is the database not stored in RAM then for sheer speed?
It was only a passing thought, I am not a database man
but a HW oriented man instead.
73...
Team AMIGA...
PostPosted: Fri Nov 23, 2012 8:14 pm    Post subject: Reply with quote
It may all be loaded into RAM if it is small enough and there is enough RAM. But even so, every change (commit) must be saved to a non-volatile medium such as a hard disc, so that the system can recover it following an outage.
But you are right that deleting direct from the database can cause a crash. When say a user account is deleted directly, any post by that user will still link back to the account. and if someone views the post & clicks through, the software will probably assume that the account is still there to be linked to. If it isn't, expect the unexpected, such as a crash. Safer to delete posts & other fingerprints first, then the account. GUI tool designers tend to think of these sorts of things, so mandraulic GUIs tend to be more robust than direct database queries (e.g. allowing admins to lock the account but leaving out a "delete" button). And usually mandraulics is the only way to drive the GUI.
Cheers,
Guy
The eternal help vampire
Bazza
PostPosted: Fri Nov 23, 2012 9:50 pm    Post subject: Reply with quote
Thanks Guy...
I am purely a hobbyist computer user and......
The only reason why I asked the question in the first place was
because of the recent attack of spammers. As I wrote earlier I
am no expert on database related stuff but I can see events
that might occur on large sized database files loaded into
memory.
By adding new spammers, then, them being deleted just
increases memory load which eventually overruns into a disk
based swapfile and/or causes system lock up or crash due to
out of memory error. Much akin to a buffer overrun, but on
a much larger scale...
Thanks a lot, you answered my question admirably.
CYA...
73...
Team AMIGA...
PostPosted: Fri Nov 23, 2012 11:11 pm    Post subject: Reply with quote
When a user is deleted their posts still appear with their username, but there is no profile link, so you can't try to view a non-existent user that way. If you load the page while they are still a user but follow the link after they have been deleted, you just get a no such user page.
1slipperyfish
Forum Jester
PostPosted: Sat Nov 24, 2012 5:30 pm    Post subject: Reply with quote
hard work??
paul
PostPosted: Sat Nov 24, 2012 9:23 pm    Post subject: Reply with quote
1slipperyfish (troll) wrote:
hard work??
Yes, you are Razz
1slipperyfish
Forum Jester
PostPosted: Sun Nov 25, 2012 12:51 pm    Post subject: Reply with quote
nelz wrote:
1slipperyfish (troll) (troll) wrote:
hard work??
Yes, you are Razz
sudo apt-get i'm-lost
PostPosted: Sun Nov 25, 2012 2:17 pm    Post subject: Reply with quote
nelz wrote:
1slipperyfish (troll) (troll) (troll) wrote:
hard work??
Yes, you are Razz
sudo apt-get lost.
Sorry. Couldn't resist! Twisted Evil
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
1slipperyfish
Forum Jester
PostPosted: Mon Nov 26, 2012 5:12 pm    Post subject: Reply with quote
nelz wrote:
1slipperyfish (troll) (troll) (troll) (troll) wrote:
hard work??
Yes, you are Razz
sudo apt-get lost.
that's what i said but these pesky moderators keep changing my posts Mad
paul
PostPosted: Mon Nov 26, 2012 5:53 pm    Post subject: Reply with quote
Gee, I wonder why.... Rolling Eyes
It was so nice and quiet here with you absent fishy one, what have we done wrong to get you back? Or rather: what went wrong elsewhere that made you come back, gotten your ar*e kicked around in that place? Twisted Evil
PostPosted: Mon Nov 26, 2012 7:34 pm    Post subject: Reply with quote
Surely you noticed that 1sf (troll) reappeared just around the time of the spam flood? Coincidence? I think not!
Wink
1slipperyfish
Forum Jester
PostPosted: Mon Nov 26, 2012 7:46 pm    Post subject: Reply with quote
yo dm always a pleasure Razz i haven't been anywhere else but here Confused where i belong Very Happy
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic All times are GMT
Goto page 1, 2  Next
Page 1 of 2
