Reading xml file
mikejd
PostPosted: Tue Nov 13, 2012 8:13 pm    Post subject: Reading xml file Reply with quote
I have been sent a document saved in OpenOffice as an ODF file. When I open it it contains xml data and is not readily readable. I have tried to save as .sxw and .doc files but it is still the same. How do I convert this to a legible document?
any help appreciated.
PostPosted: Tue Nov 13, 2012 8:52 pm    Post subject: Reply with quote
What does the file command say it is?
Code:
file yourfile.odf
PostPosted: Tue Nov 13, 2012 9:09 pm    Post subject: Reply with quote
What app are you trying to open it in?
ODF files are XML based, so opening the raw file in a text editor would show just what you are seeing.
If that's the problem, you need an ODF compatible app such as LibreOffice, OpenOffice or Abiword - see http://en.wikipedia.org/wiki/OpenDocument for a good list.
Cheers,
Guy
The eternal help vampire
PostPosted: Tue Nov 13, 2012 10:12 pm    Post subject: Reply with quote
Most ODF formats are a zipped archive containing XML files. The flat formats, like .fodt, are plain XML but these don't seem to be used that often. file will tell you hat the file actually is, rather than what the extension is claiming it to be.
mikejd
PostPosted: Wed Nov 14, 2012 9:38 am    Post subject: Reply with quote
Thanks for the replies.
The file is a .odt format. I can open the document in LibreOffice but all I read is the xml data, the content is not readily readable. I have tried saving in different formats, eg .doc and .sxw, as suggested by various Google links but no change.
PostPosted: Wed Nov 14, 2012 9:52 am    Post subject: Reply with quote
What should the file contain?
What is the output from "file filename.odt"?
Are the contents of the file private or it is it possible to post it somewhere so we can try it?
mikejd
PostPosted: Wed Nov 14, 2012 12:57 pm    Post subject: Reply with quote
The file is a report written in OpenOffice. Not my file so I don't know what happened to it. I have been asked if I can help sort it out.
file command outputs 'OpenDocument text'
File is confidential so can't post up.
Since last post I have managed to extract the text content by a roundabout route - select all content, copy and paste into Quanta, select view which displays the text, copy the text and paste into a new doc in LibreOffice, save as .doc file. The text is completely unformatted so will need paragraphs, line breaks, etc added but at least the text is not lost and won't need to be retyped (report is 16 pages long).
So, have solved the problem for now but I still would be interested to know why it can't be opened properly in OpenOffice.
Thanks for all help.
regards,
Mike
PostPosted: Wed Nov 14, 2012 1:01 pm    Post subject: Reply with quote
Can the person who sent it to you open it? Are they using the same version of OOo?
mikejd
PostPosted: Wed Nov 14, 2012 1:06 pm    Post subject: Reply with quote
They are able to open it but it cannot be read as it is in XML. Following is first 10 lines:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?><?mso-application progid="Word.Document"?><w:wordDocument xmlns:aml="http://schemas.microsoft.com/aml/2001/core" xmlns:number="urn:oasis:names:tc:opendocument:xmlns:datastyle:1.0" xmlns:dt="uuid:C2F41010-65B3-11d1-A29F-00AA00C14882" xmlns:v="urn:schemas-microsoft-com:vml" xmlns:fo="urn:oasis:names:tc:opendocument:xmlns:xsl-fo-compatible:1.0" xmlns:w10="urn:schemas-microsoft-com:office:word" xmlns:w="http://schemas.microsoft.com/office/word/2003/wordml" xmlns:wx="http://schemas.microsoft.com/office/word/2003/auxHint" xmlns:o="urn:schemas-microsoft-com:office:office" xml:space="preserve" w:embeddedObjPresent="no">
Don't know which version they use, I am using LibreOfficev3.5.
PostPosted: Wed Nov 14, 2012 1:13 pm    Post subject: Reply with quote
I get the same if a save a document as Microsoft Word 2003 XML from LibreOffice 3.6.3.2, it's not an ODF file. However, LO can also open the file here. My guess is that something screwed up when saving the file.
mikejd
PostPosted: Wed Nov 14, 2012 1:21 pm    Post subject: Reply with quote
Thanks, nelz.
At least I now have the full text to save retyping. i guess it will have to remain a question how it got like it. Let's just blame it on Ooo on Windows not saving correctly and thank Linux for being able to retrieve the situation.
cheers.
PostPosted: Wed Nov 14, 2012 3:43 pm    Post subject: Reply with quote
I'd guess the file was save in MS Word 2003 has an xml not odf in the first instance.
Have a read of this blog, it explains how too turn it into a normal xml file.
http://blogs.msdn.com/b/brian_jones/archive/2005/07/07/436647.aspx
