Can't get Parted Magic up and running
guy13
PostPosted: Tue Oct 30, 2012 2:44 pm    Post subject: Can't get Parted Magic up and running Reply with quote
Dear all,
This is my setup: a Toshiba Satellite L650 laptop with an Intel Core i5 cpu and dual boot: Windooz 7 + Debian Squeeze.
Here's my problem: I've been trying for days now to get PartedMagic running from the cover disk of LXF 164.
I've burnt the iso to a CD-Rom and at first everything goes hunky dory: I get a screen with some options after which lots of stuff is being started and mounted if one may believe the big friendly letters saying "DONE" at the end of every line. Unfortunately when the machine gets to the pink line that says "Ejecting CDROM" the CD is ejected after which nothing happens anymore.
I've also tried option two (running live in stead of from RAM): this brings me a step further, to a desktop which then freezes completely, refusing to respond to any input from either the laptop's own keyboard or touchpad or from an external keyboard or mouse.
Finally I've tried (I think) all other options that made any sense and downloaded and burnt the most recent version of the software from Parted Magic's website but always with the same lack of success.
Any hints towards a solution are most welcome.
Thanks in advance,
Guy
PostPosted: Tue Oct 30, 2012 10:17 pm    Post subject: Reply with quote
The version I have - downloaded from the Parted Magic site - has a Live CD option - so the CD is not ejected. Have you tried that?
PostPosted: Wed Oct 31, 2012 9:41 am    Post subject: Reply with quote
I have a similar problem with one (and only one) of my PCs, must be a BIOS issue, I guess.
guy13
PostPosted: Thu Nov 01, 2012 2:21 pm    Post subject: Reply with quote
Thanks for the response.
Yes, I have tried the live CD option both with the version from the LXF DVD and downloaded versions from Parted Magic.
Meanwhile I've also been in touch with the developer(s) and at his request downloaded the test version and tried Radeon no modeset and Alternate Graphical Server both with and without livemedia added to the syntax. Unfortunately always with similar results: without the added syntax the machine hangs on or before "Ejecting CDROM". With added syntax I get a desktop which then freezes.
Will keep you informed should I find a solution.
