Yast asking for a licence agreement
Postby neilj » Fri Oct 26, 2012 8:15 am
When I download a .rpm and click on it to install it Yast pauses with a message, Licence Agreement Required.
I can install using zypper but I would prefer to use Yast
Please help
neilj
Postby Nuke » Fri Oct 26, 2012 9:23 am
I take it that this is in OpenSuse? Version?
And what happens then? Are you required to tick a box (in which case, what are you being asked to agree?), or do you have to type in the words of GPL 3 (or some other) yourself, or does it just freeze at that point?
Nuke
Postby neilj » Fri Oct 26, 2012 12:04 pm
Yes it is OpenSuse 12.1.
Nothing happens it just sits there. There is nothing to click on, nothing to go to the next step. There is a box in the middle of the screen with a blue block running back and forth and nothing else.
neilj
Postby wyliecoyoteuk » Fri Oct 26, 2012 3:30 pm
Have you tried opening the package manager?
that might give you the option to agree the terms of the yast license.
Postby el chapulín » Fri Oct 26, 2012 4:23 pm
The problem is with the rpm itself, try to install it (as root) from the command line and see what happens e.g.
# yast -i /home/your_user/rest_of_path_etc/somefile.rpm
el chapulín
Postby neilj » Fri Oct 26, 2012 4:31 pm
Worked Thanks
neilj
