Python
Python
Postby RyanF109 » Mon Oct 22, 2012 2:55 pm
I have kept all of my coding academy tutorials and today I started the process of working my way through them.
I decided to play around with python and I am trying to create code that generates a random colour for the screen fill every time you click the mouse. But after spending a while fixing indentation errors now when I run it, it just quits with no error, as if one of the returns are being executed. Can anybody see any obvious errors in my code?
#/usr/bin/python
#import modules
import pygame
import os,random
#define colour settings class
class colourset():
   def __init__(self):
      """ colour settings """
   def gencolour(self):
      self.r = random.randint(0,255)
      self.g = random.randint(0,255)
      self.b = random.randint(0,255)
      return self
   def colourscreen(self,colour):
      self.screensize = (800,600)
          self.screen = pygame.display.set_mode(self.screensize)
          pygame.display.set_caption('Random Colour')
          self.backdrop = pygame.Surface(self.screensize)
          self.backdrop.fill((colour.r,colour.g,colour.b))
      #refresh the screen by drawing everything again
      #redrawthe background
      self.screen.blit(self.backdrop, (0, 0))
      #flip the buffer
      pygame.display.flip()
def main():
   """the main game logic"""
   #Initialize Everything
   pygame.init()
   colourinst = colourset()
   colour = colourinst.gencolour()
   colourinst.colourscreen(colour)
   clock = pygame.time.Clock()
   # control loop
   while 1:
      #adjust this timer to make the game harder or easier
      clock.tick(130)
      #check what events Pygame has caught
      for event in pygame.event.get():
          if event.type == pygame.QUIT:
         return
          elif event.type == pygame.KEYDOWN and event.key == pygame.K_ESCAPE:
         return
          elif event.type == pygame.MOUSEBUTTONDOWN:
         #button means mouse click
   if __name__ == '__main__':
          main()
          pygame.quit()
[/code]
RyanF109
Postby RyanF109 » Mon Oct 22, 2012 9:54 pm
I fixed it. It was an indentation error. I'm not used to indentation being so important!
RyanF109
Postby lok1950 » Mon Oct 22, 2012 10:44 pm
If you are using gedit or kwrite you can set syntax checking for a variety of languages.
Enjoy the Choice :)
lok1950
Users browsing this forum: pauldmallett, Yahoo [Bot] and 2 guests
