qt creator and iostream
Postby alansecker » Sun Oct 21, 2012 12:23 pm
I have installed qt creator from the Mageia 2 repository. When I 'build' my tiny test routine that contains the line
#include <iostream>
qt returns: iostream: No such file or directory.
I have been unable to identify which library file might contain it.
I've left messages on qt's forum and the Mageia newsgroup but so far, no really useful reply. This appears to be the 'Last Chance Saloon'
alansecker
Postby Bruno » Mon Oct 22, 2012 10:29 am
Hi alansecker,
On my openSUSE 11.4 system, the file you require is located in:
/usr/include/c++/<version_number>/
so I would try looking there on your system. I've had similar problems in the past with the compiler not finding things that are definitely in /usr/include/ and sub-directories thereof, but I am unsure why this happens.
Searching for "where is iostream" on the internet gives an interesting page here: http://www.linuxforums.org/forum/programming-scripting/98283-where-iostream-h.html. This user is just starting out. I don't know if you are in the same situation, but some of this user's problems seem to be caused by using both C and C++ conventions in the code.
HTH, Bruno
Bruno
Postby alansecker » Mon Oct 22, 2012 8:47 pm
You are absolutely right! The number is 4.6.3 but why qt creator cannot find it is the next problem to solve.
Thank you very much indeed.
Regards
Alan
alansecker
