SOLVED - Shutdown* laptop when mains is disconnected
Postby FranBlakes » Sat Oct 13, 2012 9:28 am
I'm using Ubuntu 10.04 LTS on an ageing laptop.
The battery only lasts 1min 40sec appx.
When the battery dies, the BIOS resets :(
So is there a way that when mains is disconnected eg power failure, the laptop would hibernate or shutdown. Hibernate takes 45secs.
Any help would be appreciated :)
Ubuntu 10.04.4 LTS!
FranBlakes
Postby nelz » Sat Oct 13, 2012 9:08 pm
Try putting this in /etc/acpi/events/unplugged
event=ac_adapter.*0$
action=/usr/sbin/hibernate
The first line matches on an ACPI event sent when the AC adaptor is unplugged, the action should be set to whatever command your system needs to initiate hibernation.
This is only a very temporary fix though, soon your battery will last even less time, or none at all, as mine recently started doing.
Postby FranBlakes » Sat Oct 13, 2012 10:36 pm
Thanks nelz!
The laptop has always plugged in, which they say damages the battery.
The command I had to use, just in case any 10.04 users need it is
pm-hibernate
Ubuntu 10.04.4 LTS!
FranBlakes
Postby Ram » Sun Oct 14, 2012 9:01 pm
Take the battery out if always on the mains.
Postby nelz » Sun Oct 14, 2012 11:28 pm
Then he loses the 100 seconds of grace that the battery still gives him. A laptop battery acts as a UPS when running off the mains.
Postby Ram » Mon Oct 15, 2012 7:57 am
I was thinking more on the lines of saving the life of the battery.
For my works business laptops they advice not have them connected permanently for any longer than 2 weeks.
Postby FranBlakes » Tue Oct 16, 2012 7:09 pm
I have switched the laptop on whilst unknowingly unplugged - only have to go through the slow boot on next power-up (due to BIOS resetting).
It's a wonder they don't make laptops/batteries that when charged 100% `disconnect` from the mains, then start re-charging when the battery reaches 20%.
Just wondering how long the battery will last before it wont charge...
Ubuntu 10.04.4 LTS!
FranBlakes
Postby Ram » Tue Oct 16, 2012 10:34 pm
The daughters Medion lasted 19 / 20 months before it stopped charging...
Users browsing this forum: Google [Bot], Yahoo [Bot] and 8 guests
