Search
Search
Postby jobex » Sat Oct 13, 2012 2:53 pm
How does the "Search" facility on this website work? I enter a keyword such as "resolution" to try to find anything about how to change my display to something more appropriate and I get reams of results with no obvious connection to my search parameters. I can sometimes find what I am looking for hidden in this haystack but why is all the other stuff showing up?
Perhaps I'm not using the search tool properly. If I search the whole of the Internet using Google I usually get results narrowed down to very near what I want. I appreciate that LFX forums are not Google but I find the lack of precision very frustrating. Maybe someone can show me how to carry out a successful search, say of the "Help" forum, in case I have got it quite wrong.
jobex
Postby Paradigm Shifter » Sat Oct 13, 2012 3:32 pm
If you mean on the forums, well, blame that on phpBB... although many other forum systems aren't that much better. :(
Paradigm Shifter
Postby ajgreeny » Sat Oct 13, 2012 8:18 pm
If you use google you need to set the site so use
searchterm site:linuxformat.com/forums
in the google box and you'll get much better results.
That works for just about any website that you want to search that has no decent search system on the site itself.
ajgreeny
Postby wyliecoyoteuk » Sat Oct 13, 2012 8:51 pm
a broad search like that will return every post containing the word "resolution"
Postby ajgreeny » Sun Oct 14, 2012 11:46 am
wyliecoyoteuk wrote:a broad search like that will return every post containing the word "resolution"
Which is precisely why you need to learn to use better search terms or put the search phrase in quotes.
ajgreeny
Search
Postby jobex » Sun Oct 14, 2012 12:49 pm
I'm fully aware of how to phrase search terms and gave "Resolution" as a simple example. However, no matter how simple or sophisticated the arrangement of keywords is, in my experience on this site, the results are very non-specific. I have not waded through a whole set of results but I get the impression that many do not contain any reference to the search terms I have used. I may be wrong about that as I have never checked carefully but I made this query because it seems to me that the search facility does not work well.
Thanks for the positive suggestion from ajgreeny. I will try that.
jobex
Postby jobex » Sun Oct 14, 2012 1:04 pm
I have just tried
and it works a treat. Brilliant. I hope others will find it useful too.
Thanks very much.
jobex
Return to This Website
