can't remove a file from a USB drive
Postby heiowge » Thu Jul 12, 2012 7:48 pm
I've got a USB stick with a couple of files on it I need gone. After dolphin failed, I tried CLI. As root, I was unable to remove them.
rm: cannot remove `torch 23.JPG': Read-only file system
Any help?
Postby heiowge » Thu Jul 12, 2012 7:57 pm
Ok, the files are gone. I unmounted and remounted the stick and I could suddenly do it!:oops:
I still want an answer to the question though... how do I change the permissions so I can delete read only files in the future (without pulling the stick)?
I've been trying to wrap my head around chown and chmod, thinking they were the sort of things I should be looking at, but Gaaarrrgghh!!! They talk all "man pages" at me. :roll:
Postby Rhakios » Thu Jul 12, 2012 8:06 pm
Sometimes it's as simple as going to the file's properties in your preferred file manager and ticking the Write box. However, as your error seems to indicate a read only file system, I assume the stick itself hadn't mounted properly, that's a bit odd, presumably after you pulled it and reinserted it, it remounted rw, as one would expect.
Postby heiowge » Thu Jul 12, 2012 8:15 pm
Something like that. I did reach from my little CLI book, but it's not there. I think it's in the loft and I left the Fedora based Linux guide down here instead. The book isn't in plain English. It's like "Man pages - the full volume!" :lol:
Postby Rhakios » Thu Jul 12, 2012 9:48 pm
I have "Linux Command: Instant Reference" which is a bit like that, but it's one short reach from my desk. And much better than "Linux Complete", which is basically just all of man from a particular era in print.
Postby Ram » Thu Jul 12, 2012 10:11 pm
Postby wyliecoyoteuk » Fri Jul 13, 2012 11:38 am
If it was saying "read only file system", then it was mounted as read only, i.e. like CD.
Postby nelz » Tue Jul 17, 2012 11:19 pm
It said read-only filesystem, not read-only file, so chmod won't help. In fact it won't do anything because the filesystem is read-only. This is not unusual with USB sticks and is usually caused by a filesystem error causing the kernel to mount the stick read-only to prevent damage. Unmounting and remounting the stick generally works, unless the filesystem is already damaged.
Postby JimCameron » Tue Sep 11, 2012 10:11 am
Long Path Tool helped me in this situation. http://DeleteLongFile.com
JimCameron
Postby heiowge » Tue Sep 11, 2012 11:02 am
You are aware this is a LINUX forum? :roll:
Postby Ram » Tue Sep 11, 2012 11:57 am
heiowge wrote:You are aware this is a LINUX forum? :roll:
This made me laugh
No special system requirements. LONG PATH Tool works on any Windows version (NT/2000/XP/Vista/Windows 7).
Postby Rhakios » Tue Sep 11, 2012 7:42 pm
This made me laugh
Or indeed, knife, fork and plate. :)
Postby Nelson32 » Sat Oct 06, 2012 2:43 pm
Long Path Tool helped me in this situation, but don't listen to a stupid spammer like me.
Nelson32
Postby Ram » Sat Oct 06, 2012 4:39 pm
Think you should lock this thread, might stop the stupid idiots posting.
Postby nelz » Sat Oct 06, 2012 4:42 pm
I'd rather delete the idiots than prevent genuine users being able to use the thread.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
