jbh911
Joined: Sat Jan 07, 2012 7:31 am Posts: 12 Location: Victoria Australia
Posted: Tue Aug 14, 2012 4:54 am Post subject: Dual installation W7 & LM12 - W7 won't boot |
LM 12 installed in dual boot configuration with functioning W7. However, although W7 appears in the selection screen it won't boot from there.
I've followed the advise in the LXF 133 page 44 Troubleshooting FAQ as part of Perfecting multi-booting topic re this very issue - and it doesn't help. Are the details of that article all correct?
I have W7 is at /dev/sdb1 and LM12 at/edv/sdb5. What do I need to do to get W7 booting?
Mayhem
Posted: Sat Aug 25, 2012 11:49 pm Post subject: |
Booting W7 and ... ? I have found some linux flavours dont play nicely, but most can be easily fixed.
Do you get a menu to choose from ?
Try boot into linux. edit /boot/grub/grub.cfg (I can hear pitch forks a-comming...)
Find your W7 entry and try changing up or down a disk number and see if that works. I've found that the numbers/letters are sometimes misleading, depending on what OS is reading them at what time. |
jbh911
Posted: Wed Sep 12, 2012 5:07 am Post subject: |
Thanks for the suggestion Mayhem. Will see how that goes.
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7994 Location: Warrington, UK
Posted: Wed Sep 12, 2012 8:56 am Post subject: |
What does "won't boot" mean? Does anything happen when you select W7? If so, what? What messages, if any, do you see?
Please post the contents of /boot/grub/grub.cfg, using code tags to keep it readable. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
jbh911
Posted: Tue Sep 18, 2012 8:14 am Post subject: |
Got it sorted - can't recall the detail.
Thanks for the suggestions.
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Tue Sep 18, 2012 8:32 am Post subject: |
| jbh911 wrote: | Got it sorted - can't recall the detail.
Was that too much Fosters and 4X  _________________
jbh911
Posted: Fri Sep 21, 2012 8:45 am Post subject: |
Too much red!
