KDE clock keeps going UTC
Postby heiowge » Fri Sep 14, 2012 1:00 pm
I keep losing an hour. Yesterday I rebooted and my clock went from London time to UTC (London time - 1 hour).
I reset it and find this morning it's back to UTC.
Any ideas?
Postby Ram » Fri Sep 14, 2012 1:09 pm
Are you dual booting this machine.... Windows does the same thing on my machine.
Postby heiowge » Fri Sep 14, 2012 1:30 pm
Yes, but I've never had it happen before. Then again, Windows kept crashing yesterday while I was playing Fallout 3.
I got annoyed and uninstalled it, btw. :roll:
Postby Ram » Fri Sep 14, 2012 1:52 pm
heiowge wrote:Yes, but I've never had it happen before. Then again, Windows kept crashing yesterday while I was playing Fallout 3.
The game or Windows.
Just check that your BIOS / Windows and KDE are all set the same.
Postby el chapulín » Fri Sep 14, 2012 2:05 pm
Set your system BIOS clock to UTC and then configure KDE to follow UTC and set up your timezone, etc... you'll also need to set up windows to do that same - no idea on that one...
I had a similar problem dual booting Debian and FreeBSD about 6 months ago.
el chapulín
Postby heiowge » Fri Sep 14, 2012 2:35 pm
I don't want it on UTC though. We are all on British Summer time here.
Postby Ram » Fri Sep 14, 2012 2:45 pm
heiowge wrote:I don't want it on UTC though. We are all on British Summer time here.
You living in a parallel universe, what BST?
Postby roseway » Fri Sep 14, 2012 5:47 pm
As far as I know, Windows doesn't know about UTC, so if you're dual-booting with Windows you have to set your Linux system to use local time, not UTC. It's an installation option, but I'm not sure how to do it on a running system.
Eric
roseway
Postby heiowge » Sat Sep 15, 2012 8:05 am
I think I've got it for the moment. It was defaulting to UTC. I changed it to London time. There must have been something that restored to default occasionally...
Postby el chapulín » Mon Sep 17, 2012 8:51 am
roseway wrote:As far as I know, Windows doesn't know about UTC, so if you're dual-booting with Windows you have to set your Linux system to use local time, not UTC. It's an installation option, but I'm not sure how to do it on a running system.
Assuming the OP is running Linux Mint, which is Debian-like, then
# dpkg-reconfigure tzdata
el chapulín
Postby Ram » Mon Sep 17, 2012 11:17 am
Windows 7 uses UTC.
Users browsing this forum: Yahoo [Bot] and 5 guests
