What utility do you use to burn multilive DVDs?
Post new topic   Reply to topic    Linux Format forums Forum Index -> Magazine and coverdiscs
blackspot
PostPosted: Thu Aug 16, 2012 4:54 pm    Post subject: What utility do you use to burn multilive DVDs? Reply with quote
Is it a Linux or Windows program?
For Linux, I've heard of the limited 'multicd' script. There appears to be better utilities for Windows.
I'm looking for a Linux utility or script(s) so I may take the Linux LiveCD ISOs I've downloaded from the net, or from your DVDs, and create my own custom multi-live chooser LiveDVDs. Thank you.
M-Saunders
PostPosted: Sat Aug 18, 2012 9:53 am    Post subject: Reply with quote
Hi!
I can't speak for Ben, but when I used to make the LXF DVDs, I integrated the different distros manually. There's no magic tool to do it all automatically for any distro -- sure, there are things like multicd, but they only work with certain distros.
Ultimately, most distros have different directory layouts, boot options etc., so you have to be aware of these differences when fitting them all together on a single disc. It can get pretty complicated, and I did a lot of hacking on initrds and boot scripts back in the day.
Hope that helps!
Mike
lok1950
PostPosted: Sat Aug 18, 2012 5:15 pm    Post subject: Reply with quote
And got quite good at it Mike Wink
Enjoy the Choice Smile
blackspot
PostPosted: Sun Sep 02, 2012 12:11 am    Post subject: Reply with quote
thanks. anyone else?
blackspot
PostPosted: Sun Sep 02, 2012 7:04 am    Post subject: Reply with quote
Here are some possible tools I've found:
Quote:
# Buildroot package
http://buildroot.uclibc.org
Used to build basic ARL Linux distribution from scratch. ARL contains some patches and extensions to the Buildroot, which are included in the ARL package.
# Syslinux package
http://www.kernel.org/pub/linux/utils/boot/syslinux
Used binary files allowing to create bootable iso and usb stick.
# Testdisk package
http://www.cgsecurity.org
Used binary utility testdisk and photoreg.
# Chntpw package
http://pogostick.net/~pnh/ntpasswd
Used statically linked utility chntpw and reged.
# Memtest86+ package
http://www.memtest.org
Used bootable binary allowing to start memory test during boot.
# ARL package
https://share.avg.com/arl
This package contains modified free version of AVG for Linux, patches, configuration files and other stuff needed by AVG and buildroot.
For more info see the ARL Package_Structure
iwlwifi microcode images
http://intellinuxwireless.org/iwlwifi/downloads
3945, 4965, 5000, 5150, 1000, 6000
ipw2200 microcode images
http://bughost.org/firmware
PostPosted: Sun Sep 02, 2012 11:13 am    Post subject: Reply with quote
There are so many ways of booting distros that manual examination of each one is the only reliable way of doing it. Chainloading the syslinux bootloader for each distro from a master one works best, but you also have to fiddle with boot parameters, or even edit init scripts in initrd images, because so many distro boot systems work on the assumption you are booting from the root of an optical device.
There is no magic bullet that works for all distros.
Post new topic   Reply to topic    Linux Format forums Forum Index -> Magazine and coverdiscs All times are GMT
