fstab Problem! Can't access my system, emergency mode only
Postby lobo » Fri Aug 17, 2012 7:48 pm
I can't do anything on my computer
Dear all,
I was previously experimenting problems, after upgrading from Opensuse 11.4 (KDE) to 12.1 (KDE) in which I was unable to edit an external HD I had been using before without any issues. In 12.1 I was able to read and copy files from it to the main drive, but was unable to edit anything (save changes, delete or add files etc.) within the external drive. Also, the mentioned external drive (NTFS) appeared as a windows partition under "Windows D". (In 11.4, it simply showed as part of "media" directory).
So I went on the official forum, and after I was asked to show the fstab, I was advised to introduce some changes to the fstab.
from code line:
/dev/disk/by-id/ata-WDC_WD5000AAJS-00A8B0_WD-WMASY0638851-part1 /windows/D ntfs-3g users,gid=users,fmask=133,dmask=022,locale=en_US.UTF-8,nofail 0 0
- I was advised to set it to "default", which I did...
For a moment, I was able to regain full functionality from the external drive and everything was going really well. I even shut down for a few hours and turned the computer back on with no problems.
However, since the following morning I have been unable to boot to my system!! After a longer than usual booting time, I am greeted with a screen showing the ongoing boot processes, ending with the following message (manually typed from my pc screen to my laptop and preceded by more text):
Started /home [ OK ]
[ 11.541335] ALSA via82xx.c:591 codec_read: codec 0 is not valid [0xfe0000]
[ 11.552311] ALSA via82xx.c:591 codec_read: codec 0 is not valid [0xfe0000]
[ 11.568750] ALSA via82xx.c:591 codec_read: codec 0 is not valid [0xfe0000]
[ 11.576408] ALSA via82xx.c:591 codec_read: codec 0 is not valid [0xfe0000]
Dependency failed. Aborted start of /windows/D [ ABORT ]
Welcome to emergency mode. Use "systemct1 default" or ^D to activate default mode.
Give root password for login;
- I entered my root password, then got:
linux-hrmj: ~ #
* I was advised to use installation DVD but could not get it to work.
* Then I was advised to look into the fstab "vi /etc/fstab" to add "#" to the beginning of the line "/windows/D" in "/etc/fstab".
I can see the file and hover through it with the arrow keys, but am unable to introduce any changes.
It seems that at the other forum they are too busy or just gave up on me. Unfortunately I am not an expert in Linux and not very experienced with its inner functions...
In the meantime I am loosing hours of productivity.
Please...What can I do to get my system back?
Thank you very much for your help and suggestions!
lobo
Postby nelz » Fri Aug 17, 2012 7:58 pm
That's because vi is the spawn of the devil and you need to switch this text editor into editing mode before you can actually edit any text with it, then switch back out to save your changes. The simple answer is to use nano instead of vi, where a simple Ctrl-X saves your changes.
You don't say how you changed /etc/fstab, you added default, but where? However, I think you should remove the line for this disk entirely, or comment it out. It appears the installer thought this was a fixed drive, hence adding it to the fstab. Removable drives don't belong in here, they are automatically mounted under /media with suitable permissions for the user running the desktop, just like you had with your previous installation.
Postby lobo » Fri Aug 17, 2012 9:01 pm
Hello Nelz! Thank you very much for your reply.
The earlier change to fstab I did was done while my only problem was not being able to edit my external HD. Everything else was working fine. I accessed it by:
"Alt-F2: kdesu kwrite /etc/fstab"
I then replaced the last portion of the text in "windows D" line (users,gid=users,fmask=133,dmask=022,locale=en_US.UTF-8,nofail) with "default"
After being unable to access my pc, I also tried using nano (as advised on another forum) by "nano /etc/fstab", but it then showed the message "if 'nano' is not a typo you can use command....."
I just tried again with no avail. Am I writing it wrong or maybe I just don't have nano??
lobo
Postby nelz » Fri Aug 17, 2012 9:17 pm
There are three problems here. The first is that you have a removable drive in fstab, they don't belong there and it is why you could not write to it (devices in fstab are mounted by root). The second is that you added an incorrect option to the fstab line - it is defaults not default, and it wouldn't have made the disk writable by a user anyway (the correct approach would be to fix the umask setting). Finally, you don't have nano installed, so you'll have to use vi. Press i to enter insert (edit) mode, add a # to the start of the offending line. Press Esc to go back to command mode and enter :wq to save and exit.
Vi makes the Windows idea of pressing the Start button to shutdown seem positively intuitive :shock:
Postby lobo » Fri Aug 17, 2012 9:51 pm
Thanks and agree! trying it out now!
lobo
Postby lobo » Fri Aug 17, 2012 10:21 pm
I hit "i", added "#" to the beginning of the line, then ESC and :wq
Restarted twice and nothing happened. I continue to get the same message prompting me to give root password for emergency mode. This is getting really frustrating... what else can I do?..
(Maybe my mistake is here? I placed # :
"# /dev/disk/by-id/ata-WDC_WD5000AAJS-00A8B0_WD-WMASY0638851-part1 /windows/D ntfs-3g defaults 0 0
PS: It always said "defaults" and nor "default", my mistake in copying..)
Thanks again!
lobo
Postby nelz » Fri Aug 17, 2012 10:29 pm
When you get to the emergency command prompt, what does running
mount -a
report?
Postby lobo » Fri Aug 17, 2012 10:57 pm
I get a rather long text.
it states:
ntfs-3g: failed to access volume '/dev/disk/by-id/ata-WDC_WD5000AAJS-00A8B0_WD-WMASY0638851-part1' : No such file or directory
ntfs-3g 2011.4.12 integrated FUSE 27 - Third Generation NTFS Driver
configuration driver type 1, XATTRS are on, POSIX ACLS are off
- then there 4 lines showing copyrights, then:
Usage: ntfs-3g [-o option [,...]] <device| image_file> <mount_point>
Options: ro (read-only mount). remove_hiberfile, uid=, gid=,
umask=, fmask=, dmask=, streams_interface=.
Please see the details in manual (type: man ntfs-3g)
Example: ntfs-3 /dev/sda1 /mnt/windows
News, support and information: http://tuxera.com
- This was copied from the screen to my laptop by hand.
Thanks!
lobo
Postby nelz » Mon Aug 20, 2012 8:16 am
It is still trying to mount the external drive, all lines referring to it need to be removed or commented.
Postby lobo » Mon Aug 20, 2012 2:02 pm
Hello again Nelz and thanks again.
Yes. It reads:
Welcome to emergency mode.............etcetera
Would it be correcto to:
vi /etc/fstab
then just delete the entire line?
lobo
Postby lobo » Mon Aug 20, 2012 2:57 pm
I think there has been some progress, though I may have commited some errors these last days while trying to fix things through vi:
After startup, I am now finally prompted to enter my user password at the regular login screen. However, when I enter the password, I get the following message:
"Cannot enter home directory. Using /."
I hit enter, and another screen opens saying: "Call to lnusertemp failed (temporary directories full?). Check your installation." followed by an okay button.
I hit the okey button and greeted once again with the login screen.
Now I entered as root, and was able to enter a session, apparently ok.
Maybe things are getting better?
What should I do now or examine to get back to my main user ?
lobo
Postby lobo » Mon Aug 20, 2012 3:09 pm
lobo
Postby Dutch_Master » Mon Aug 20, 2012 3:10 pm
Better? Far from it! It appears your system has some runaway logs or other process that consumes drive space...
Best solution is to re-install, but that might mean you'd loose all data if you haven't backed up or have a separate /home partition.
Postby Ram » Mon Aug 20, 2012 3:22 pm
No No I hear nelz scramming...
Grab hold of a LiveCD and examine your system to see where the space has been used up.
Postby Dutch_Master » Mon Aug 20, 2012 4:12 pm
True, I figured Nelz would be screaming behind (or rather in front of ;)) his screen by now. But examining a Linux system via a Live CD appears to me quite useless if the user performing it has too little knowledge of a Linux system in the first place. That's why I advised the best solution is to re-install. even if that's not what Nelz wants to hear :roll:
Users browsing this forum: Google [Bot] and 5 guests
