Skype Alternative
Skype Alternative
Postby Narendra » Thu Aug 09, 2012 10:55 am
Please suggest some cheap alternatives to Skype!
Thank you.
Narendra
Narendra
Postby nelz » Thu Aug 09, 2012 11:08 am
It depends on what you want to do. If you install a SIP client, like Telepathy, then Google for SIP providers. There are tones of them , with varying rates. Which one is best for you depends on where you want to call.
Personally, I just stick with www.sipgate.co.uk
Postby ajgreeny » Thu Aug 09, 2012 7:42 pm
The biggest problem is simply that just about every other user only knows of, and therefore uses Skype.
You will therefore need some evangelism regarding VOIP applications before you can sensibly use an alternative to speak to anyone else.
ajgreeny
Postby nelz » Thu Aug 09, 2012 7:56 pm
Skype-to-Skype calls are free, so in asking for a lower cost alternative it would appear that Narenda want to use it to call POTS phones.
Postby Narendra » Fri Aug 10, 2012 8:33 am
Since MIcrosoft have taken over Skype the costs of sending SMS and calling within the Uk have gone up.
So I am looking for its alternative. Even the Sipgate is expensive.
Narendra
Narendra
Postby nelz » Fri Aug 10, 2012 8:52 am
The best price alternative for UK calls and texts is probably a mobile phone. SIP is good for calling other SIP users or abroad, but for calls to UK numbers, especially mobiles, a bundled mobile deal is usually cheapest.
Postby Narendra » Fri Aug 10, 2012 9:01 am
Narendra
Narendra
Postby mm tylor » Wed Aug 21, 2013 4:12 pm
There is best alternative of Skype is SIP. SIP is a great for making calls. Its services are good and sound quality is very well
mm tylor
Postby Narendra » Wed Aug 21, 2013 4:25 pm
I'll try using it.
Narendra
Narendra
Postby allanroger » Tue Feb 11, 2014 5:21 am
I was in a similar boat myself, looking for a Skype alternative, when I happened upon RHUB, which is what I prefer for my online collaboration. It's easy to use, and RHUB is very secure.
allanroger
Re: Skype Alternative
Postby Alex01UK » Fri Feb 14, 2014 1:04 pm
Narendra wrote:Please suggest some cheap alternatives to Skype!
Thank you.
I use the Pidgin client, with all the plugins installed. to connect to the icq network. Pidgin does all the formats, even skype. at last count, msn, yahoo, skype, goggle and aol configured just now. I think. icq is the best overall though I find, for me. Loads of eye candy makes you appear in colours etc where others don't have the option! dyslexic acid off the internet is **** it is at! Just now, ThatIs. ie for instance / that is!
13.3'' Apple MacBook Pro: OS X Yosemite, 64bit Unicorn Studio 14.1o, 32bit Mint 17.1 MATE
Alex01UK
Postby ajgreeny » Sat Feb 15, 2014 3:21 pm
Thank you.
Are you certain it will connect to skype?
Last time I asked about this I was told that skype only talked to skype.
Have things changed now M$ has taken over at skype? It seems unlikely to me, but who knows?
ajgreeny
Postby towy71 » Sun Feb 16, 2014 11:00 am
if you just want computer to computer conversations you could try https://talky.io which a brilliant way of video conferencing securely just using chrome browser
Postby Alex01UK » Mon Feb 17, 2014 11:33 am
> Last time I asked about this I was told that skype only talked to > skype.
The Pidgin client will definitely connect to the skype network. Whether or not somebody connected to the skype network can chat to somebody on google or msn etc I have no idea. I think skype to msn might be possible now but I don't know 1oo%
My understanding, is that the Pidgin Client will do everything that the official skype client can do regarding talking to other people.
hth, from Alex.
Alex01UK
Postby Bazza » Fri Feb 21, 2014 9:07 pm
We do a great deal with the EADS Corporation.
They tore apart Skype a few years ago.
This might be worth a read:-
https://www.ossir.org/windows/supports/ ... _Skype.pdf
73...
Team AMIGA...
Bazza
