Dutch_Master LXF regular
Posted: Wed Feb 29, 2012 6:13 pm Post subject: |
Coverage on the BBC News at 6 today. Great!  |
Posted: Tue Apr 17, 2012 4:27 am Post subject: |
And the first (pre-)orders have now been delivered, directly from the Foundation. Those ordered at Farnell et all can expect them too in the not so distant future I assume. Maybe send one over to Mike, so he can tinker with it? And port MikeOS too Hmmm, there's a thought: if Mike re-writes his assembler articles for use on the RPi and submits them to the Foundation, who knows he might have inspired the next Linus! Or RMS  |
Posted: Thu Aug 02, 2012 2:49 am Post subject: |
Just a quick update: recently both vendors have lifted the 'one-per-person' limit imposed so far, so order the amount you want w/o restrictions! That said, at least one reseller advises you to contact them in advance if you want to order a large number  |
leke LXF regular
Joined: Mon Oct 22, 2007 6:45 pm Posts: 479 Location: Oulu, Finland
Posted: Thu Aug 02, 2012 8:21 am Post subject: |
I've had a little time to play with my pi, and noticed the hdmi video doesn't 'work' that often. The analogue video works 100% of the time though.
I have a feeling it's my tv though because I've had issues connecting things to it in the past. _________________ I codes here: http://notsure.tk |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1552 Location: Guisborough
Posted: Thu Aug 02, 2012 8:27 am Post subject: |
| leke wrote: | I've had a little time to play with my pi, and noticed the hdmi video doesn't 'work' that often. The analogue video works 100% of the time though.
I have a feeling it's my tv though because I've had issues connecting things to it in the past. |
In what way ? _________________
leke LXF regular
Posted: Thu Aug 02, 2012 8:32 am Post subject: |
| Ram wrote: | | leke wrote: | I've had a little time to play with my pi, and noticed the hdmi video doesn't 'work' that often. The analogue video works 100% of the time though.
In what way ? |
the os boots, but the tv says 'no signal'. I hear it's because there may be some problems identifying the tv settings. _________________ I codes here: http://notsure.tk |
Ram LXF regular
Posted: Thu Aug 02, 2012 8:47 am Post subject: |
Ah, that not something I've experienced. I get over scanning if I leave to TV set to auto detect the resolution - just have to change the TV to 16:9. _________________
nelz Moderator
Posted: Thu Aug 02, 2012 9:11 am Post subject: |
If you use the new Raspbian release, the config program that runs on first boot includes an option to disable the overscan. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
leke LXF regular
Posted: Thu Aug 02, 2012 9:38 am Post subject: |
| nelz wrote: | | If you use the new Raspbian release, the config program that runs on first boot includes an option to disable the overscan. |
I'm using raspbian, but if I'm not using it for the first time, where would the option for turning off the overscan be? I really should look into what overscan means as well
I'll also try and disable it on the tv and play with some of the other settings. Previously, I was playing with them after the pi had booted, but realise now I should change them before boot occurs. _________________ I codes here: http://notsure.tk |
Ram LXF regular
Posted: Thu Aug 02, 2012 9:59 am Post subject: |
| leke wrote: | | nelz wrote: | | If you use the new Raspbian release, the config program that runs on first boot includes an option to disable the overscan. |
I'll also try and disable it on the tv and play with some of the other settings. Previously, I was playing with them after the pi had booted, but realise now I should change them before boot occurs. |
Over scan = zoomed picture so say you're running gnome 2, the top & bottom panels would be off the screen. _________________
nelz Moderator
Posted: Thu Aug 02, 2012 11:22 am Post subject: |
SiriusHardware
Posted: Tue Sep 25, 2012 10:30 pm Post subject: |
For the HDMI problem, there are a vast number of preset HDMI modes which you can force the Pi to run in:
In the small partition on the card (readable / writable by Windows as well) there is a file, config.txt - this is more or less the equivalent of the BIOS setup page on a more conventional computer. If you are a Linux newcomer (as I am) you may find it easier to put the card into a card reader on a Windows PC and use that to locate/edit config.txt.
There's a huge list of the possible settings which can be used in config.txt over on the raspberry pi Wiki on elinux - hope it's OK to post the link here?
http://elinux.org/RPi_config.txt
You could try adding / changing the HDMI mode setting to
hdmi_mode=19
Which equates to 720p, 50Hz.
Maybe your TV does not support 1080? Some of the first wave of 'HD ready' TVs didn't support resolutions higher than 720.
Other settings can be changed to adjust the HDMI signal drive level. |
leke LXF regular
Posted: Wed Sep 26, 2012 5:38 pm Post subject: |
| SiriusHardware wrote: | For the HDMI problem, there are a vast number of preset HDMI modes which you can force the Pi to run in:
hdmi_mode=19
Other settings can be changed to adjust the HDMI signal drive level. | Hi, thanks for the suggestion. I found this info a little while back, but forgot to mark the problem as solved
Sorry about that, and thanks again  _________________ I codes here: http://notsure.tk |
