Sound drivers and hardware scans. Solved.
Postby Rhakios » Fri Feb 03, 2012 6:59 am
But I get:
# dmidecode 2.9
SMBIOS 2.4 present.
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer: ASUSTek Computer INC.
Product Name: NARRA
Version: 1.01
Serial Number: MS1C73S32400696
Actually the motherboard is an Asus M2N68-LA, NARRA is just what HP call it. I wonder if the output depends a lot on whether the machine is home-built, or from a big manufacturer. I had a look at the same thing on my Toshiba laptop last night, and that was pretty uninformative about the motherboard's proper name as well.
Postby wyliecoyoteuk » Fri Feb 03, 2012 10:37 am
Probably depends on the reseller, HP and Dell tend to use customised motherboards.
On my Lenovo laptop I get:
# dmidecode 2.9
SMBIOS 2.6 present.
Handle 0x000E, DMI type 2, 15 bytes
Manufacturer: LENOVO
Product Name: 11433LG
Version: Not Available
Serial Number: 1ZKYF1AP4B3
Asset Tag: Not Available
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Not Available
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Postby towy71 » Fri Feb 03, 2012 10:58 am
On my Acer Aspire M1640 gives
# dmidecode 2.9
SMBIOS 2.5 present.
Handle 0x0002, DMI type 2, 15 bytes
   Manufacturer: ACER
   Product Name: MCP73
   Version: NVIDIA MCP73
   Serial Number: 000000000
   Asset Tag: To Be Filled By O.E.M.
   Features:
   Location In Chassis: To Be Filled By O.E.M.
   Chassis Handle: 0x0003
   Type: Motherboard
Well it seems the OEM is a bit not there ;-)
Postby Weatherlawyer » Tue Jul 31, 2012 2:48 am
What's the difference between terminal and byobu terminal?
They look identical.
I used hwinfo and got a stupid amount of info mainly about partition on my drives and my drives and USB connections.
No sign of the MOBO.
I would very much like to be nice. If this is not your day, I am sorry about that.
Weatherlawyer
Postby nelz » Tue Jul 31, 2012 9:11 am
byobu is a theme for screen, which runs inside a terminal but can be detached and reattached to a different terminal at will.
Try lshw, I find it more useful than hwinfo and it does give motherboard information.
Postby Weatherlawyer » Tue Jul 31, 2012 9:29 am
nelz wrote:byobu is a theme for screen, which runs inside a terminal but can be detached and reattached to a different terminal at will.
Wilco.
I played with byobu last night and suddenly realised that it was holding my mother board's name on the bottom panel.
Thinking about the install I suddenly realised Ubuntu had forced me to name the computer with that odd number on it. I had assumed it was just a random code number made up on the spot. :oops:
ishw found the spot others just can't reach.
My motherboard and the graphics card are no longer someone else's secret.
Thanks to all. :D
Weatherlawyer
Postby Weatherlawyer » Tue Jul 31, 2012 9:39 am
MessedUpHare wrote:you could use dmidecode to find what the motherboard is saying it is... you havto run it as root, though...
# dmidecode -t 2
[/code]
How do I get it to allow me on as superuser or root?
Also I need to learn some useful commands the Gnome terminal help wasn't, much. Very easy to understand though.
Weatherlawyer
Postby towy71 » Tue Jul 31, 2012 10:16 am
sudo dmidecode -t 2
will get you what you want :wink:
Postby Weatherlawyer » Thu Aug 02, 2012 4:16 pm
towy71 wrote:
sudo dmidecode -t 2
Manufacturer:
Product Name: P4i65G
Version: 1.00
Weatherlawyer
Users browsing this forum: Alex01UK and 4 guests
