Skip rope jumping, counting
Postby thusgaard » Sat Jul 28, 2012 1:58 pm
Hi
Is it possible to use a webcam to count how many jumps I do while skip roping.
And displaying the number live on a screen!
Kind regards Thusgaard
thusgaard
Postby Dutch_Master » Sat Jul 28, 2012 6:43 pm
In theory: yes. In practice: only if you have a lot of time on your hands and not a life to live :P
Postby lok1950 » Sat Jul 28, 2012 8:00 pm
And lots of money for the cameras and programmers as there no off the shelve app available :roll:
Enjoy the Choice :)
lok1950
Postby Bruno » Sun Jul 29, 2012 10:44 am
I think this would be difficult (but not impossible) to do on a computer with images captured by a camera. You could try a kinect (if that is the word) but you'd similarly have quite a programming overhead. Although, as an aside, I'd have a look and see if someone has written a library for counting events that occur in images/a video stream.
I think an arduino for event counting and data export to pc would be a good bet here, with skips detected by the rope breaking the beam of a diode laser targeted at a light dependent resistor or a photodiode.
Bruno
Postby lok1950 » Sun Jul 29, 2012 3:26 pm
Bruno wrote:I think an arduino for event counting and data export to pc would be a good bet here, with skips detected by the rope breaking the beam of a diode laser targeted at a light dependent resistor or a photodiode.
Which defeats the OP's purpose of using a camera :wink:
Enjoy the Choice :)
lok1950
Postby einonm » Mon Jul 30, 2012 9:07 pm
Yes! I think it's eminently possible.
I think you should check out OpenCV -
http://opencv.willowgarage.com/wiki/
And try looking for some similar vids on u-toob.
I'd be interested to see what happens!
einonm
Postby Bruno » Mon Jul 30, 2012 10:46 pm
lok1950 wrote:Which defeats the OP's purpose of using a camera :wink:
Enjoy the Choice :)
Fair point lok1950, but is the OP more interested in the goal or the method by which it is achieved? S/he might be mentioning the camera simply because that is what is to hand.
Bruno
Postby lok1950 » Mon Jul 30, 2012 11:03 pm
Could also use a microphone count the number of times the rope hits the floor but your approach Bruno would be more exact.
Enjoy the Choice :)
lok1950
