Narendra LXF regular
Joined: Wed Mar 14, 2007 4:32 pm Posts: 247 Location: East Midlands, UK.
Posted: Wed Jul 25, 2012 2:05 pm Post subject: To Incease Size Of The Home Folder In Ubuntu! |
Hello,
Please advise how do I increase the size of Home Folder in Ubuntu!
Thank you. _________________ Narendra |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 8035 Location: Warrington, UK
Posted: Wed Jul 25, 2012 2:43 pm Post subject: |
That depends on where you want to get the extra space from? How is your disk partitioned? _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Posted: Wed Jul 25, 2012 7:40 pm Post subject: |
I have SATA hard disk, 500 Gb, dual booting with W7. The Home folder on Ubuntu is nearly filled up and does not allow VirtualBox in Ubuntu to install Windows XP. _________________ Narendra |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1568 Location: Guisborough
Posted: Wed Jul 25, 2012 9:10 pm Post subject: |
Can you post the output produced by running in a terminal. _________________
ajgreeny LXF regular
Joined: Wed May 10, 2006 9:18 pm Posts: 412 Location: Oxfordshire.
Posted: Wed Jul 25, 2012 9:12 pm Post subject: |
Is this a wubi install of ubuntu inside windows, or did you do a proper partitioned dual boot? _________________ Xubuntu 12.04 user, and loving it! |
Posted: Thu Jul 26, 2012 10:31 am Post subject: |
narendra@narendra-desktop:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda7 43G 25G 16G 61% /
udev 4.0G 4.0K 4.0G 1% /dev
tmpfs 1.6G 964K 1.6G 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 4.0G 284K 4.0G 1% /run/shm
The out put is above.
I did partition the hard disk, did not use Wubi.
nelz Moderator
Posted: Thu Jul 26, 2012 12:04 pm Post subject: |
You have /home on the root partition and that has 16GB free, almost all of which is available for use in your home directory. The only way to get more is to reduce the size of your Windows partition and increase sda7. You need to boot from a live CD to do this and then use gparted to resize. There is a gparted live CD at http://gparted.sourceforge.net/livecd.php/ but most distro live CDs also include it (I think it is called Partition Manager in the Ubuntu live menu).
Resizing filesystems is risky, especially on a desktop machine where a power failure can cause problems, so make a backup first. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Posted: Thu Jul 26, 2012 12:56 pm Post subject: |
In spite of nelz's last comment I would strongly suggest you shrink your Win7 partition with windows own disk management utility. I am aware that users are now apparently using gparted to do it successfully, but it is always safer to use windows own utilities where they exist, particularly for partition editing, which always carries a risk, no matter how small. _________________ Xubuntu 12.04 user, and loving it! |
nelz Moderator
Posted: Thu Jul 26, 2012 5:39 pm Post subject: |
That's a good point. If Windows 7 has its own partition editor, use that to shrink the Windows partition, then use GParted to rearrange your Linux partitions. I wouldn't trust a Microsoft program to mess with Linux filesystems. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein)
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Thu Jul 26, 2012 5:56 pm Post subject: |
| nelz wrote: | | I would trust a Microsoft program to mess with Linux filesystems. | Mess up Linux file systems you mean?? I wouldn't trust Microshaft at all  _________________ still looking for that door into summer |
nelz Moderator
Posted: Thu Jul 26, 2012 7:31 pm Post subject: |
I meant to type wouldn't  _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3369 Location: Birmingham, UK
Posted: Fri Jul 27, 2012 10:01 am Post subject: |
I bought a wooden whistle but it wooden whistle.
so I bought a steel whistle but it steel wooden whistle. _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
Ram LXF regular
Posted: Fri Jul 27, 2012 10:28 am Post subject: |
| wyliecoyoteuk wrote: | I bought a wooden whistle but it wooden whistle.
so I bought a steel whistle but it steel wooden whistle. |
So you've got no poof.  _________________
Posted: Fri Jul 27, 2012 11:56 am Post subject: |
I bought a tin whistle, & now I tin whistle! _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
