Root partition size & other numpty questions
Postby nelz » Tue Jul 17, 2012 11:08 pm
Rhakios wrote:My head is aching now. Before nelz can pop in with another bogglingly complicated solution, I just want to say, back up and sort it out with a complete reinstall.
:P
If the disk is damaged, I'd say back up and replace the disk ASAP. Bad blocks have a tendency to breed like tribbles.
If you really want to use this disk, just use badblocks to map out the damaged areas. It generates a list of no-go areas on the disk that you then pass to mke2fs so it knows to mark those blocks as unavailable when it creates the filesystem.
Postby guy » Mon Jul 23, 2012 1:50 pm
update: Reinstalled debian over the top of whatever was supposed to be corrupted. Still the same symptoms.
Then I realised that the weather had been warming up. Took off the cover. Mmm, nice stable system. Moral: Box built in winter may not survive summer.
Interestingly, Mint gave my user profile a bit of a makeover that the debian reinstall then left alone. Minty debian: mm, nice.
Memo to self: get another HD before the bubble bursts.
Postby Ram » Mon Jul 23, 2012 2:57 pm
And a bigger fan :wink:
Postby guy » Mon Jul 23, 2012 5:10 pm
Ram wrote:And a bigger fan :wink:
Though I suspect it's the PSU going funny, in which case the bigger fan will draw more power....
Talking of cases, I seem to have a spare one. I feel a new build coming on.
