Black screen after 5 minutes of gaming
PostPosted: Sun Jul 22, 2012 10:52 am    Post subject: Black screen after 5 minutes of gaming Reply with quote
Ok, I'm using windows for the games, but still it's a problem.
I've just dusted the PC and cleared the fans and vents when I fitted 2 new hard drives. I find it crashes playing Fallout New Vegas and Batman Arkham Asylum after a few minutes, but can play angry birds for hours.
I know fallout is unstable, but I never had a problem with Batman before.
I suspect it's a problem with my graphics card, but could do with advice.
Oh, and Linux doesn't crash! Laughing
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
bobthebob1234
PostPosted: Sun Jul 22, 2012 12:36 pm    Post subject: Reply with quote
Overheating? Is there a temperature sensor on your graphics card that you can monitor whilst playing the games?
Which graphics card is it? Is there a known overheating problem?
Bruno
PostPosted: Sun Jul 22, 2012 2:09 pm    Post subject: Reply with quote
It is probably an overheating graphics card but it is worth checking that your PSU is able to handle the load attached to it. Have a look through the vents to see if any of the capacitors are "doming" on top or oozing anything from the top.
PostPosted: Sun Jul 22, 2012 10:36 pm    Post subject: Reply with quote
You could try and recreate it - try running glxgears in a terminal or 3
If you can't then I'd say software...
PostPosted: Mon Jul 23, 2012 9:22 am    Post subject: Reply with quote
I think it might be a windows problem. Running Fallout New Vegas under wine runs for about an hour before crashing - about normal for FNV! Laughing
PostPosted: Mon Jul 23, 2012 1:11 pm    Post subject: Reply with quote
Have a look in the Application log it might give you an indication of the fault.
Paradigm Shifter
PostPosted: Mon Jul 23, 2012 1:58 pm    Post subject: Reply with quote
What is the GPU itself? What is the PSU, and what is it rated at? (On 12v rail(s) etc?) If you've added new drives and a problem has appeared, it may suggest that when loaded there isn't quite enough power where there used to be.
If you took the HDD addition as an opportunity to update drivers too, that may have caused it.
