bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Fri Jul 20, 2012 12:21 am Post subject: openwrt using dhcp host names over hosts |
Not a show stopper, but a minor annoyance
I have my mythtv box called civo, with a static ip of 192.168.1.10. Sometimes it decides it wants to connect to my network over wifi, and then picks up a dhcp address (eg 192.168.1.100).
When this happens and I ping civo, I get 192.168.1.100. Not what I want. I have set up 'civo' as a hostname, pointing to 192.168.1.10 in the openwrt web interface.
I believe openwrt uses Dnsmasq for DNS stuff, so it is probably a problem / 'feature' with that.
Can it be stopped or the order of lookup reversed, so it uses the hosts I have defined first? _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
Dutch_Master LXF regular
Posted: Fri Jul 20, 2012 12:37 am Post subject: |
| Yes, you can specify in which order DNS should do the (reverse) lookup, can't remember where though... Also, it is possible to have the DHCP server assign an IP to a specific MAC address. And if possible (can't tell) you may want to blacklist the MAC address of the wifi card in "civo" as to disallow it to make contact that way. |
nelz Moderator
Posted: Fri Jul 20, 2012 7:47 am Post subject: |
Wouldn't it be simpler to deal with the cause of the problem and disable the wireless NIC by blacklisting its module? _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
