media server
media server
Postby blundakat » Wed Jul 18, 2012 10:06 pm
Hello
I am playing with the idea of using an old PC as a media server. The main thing I'm concerned about is power consumption, its an old Pentium D processor. I realize it will be running 24/7 but using up electricity while its not being used seems a little waste of money. I was just wondering if anyone can recommend a distro/package which is particularly good at power management?
Any advise would be much appreciated.
blundakat
Postby Dutch_Master » Wed Jul 18, 2012 11:23 pm
Every modern distro has proper power management these days. But you could run some seti@home or similar project on that machine. On a Pentium D you're not gonna get many points quickly though ;)
Postby wyliecoyoteuk » Thu Jul 19, 2012 1:01 pm
Depends what you mean by media server.
Do you want TV, or just music, video and pics?
It is possible to use a headless box, and even power down to S3 sleep mode at set times of day, or use wake on lan, if the box supports it..
If you want TV, MythTV is the best choice, especially Mythbuntu.
If you don't, check out XBMC or subsonic
Postby AndyBaxman » Thu Jul 19, 2012 2:12 pm
Would suggest MediaTomb
Works well for me and streams nicely to iPhone, Android and my LG TV.
Web based management, too, so suitable for headless deployment.
AndyBaxman
Postby Ram » Thu Jul 19, 2012 4:04 pm
AndyBaxman wrote:Would suggest MediaTomb
Works well with PS3
Postby blundakat » Thu Jul 19, 2012 6:07 pm
TV is not a must, certainly not just yet anyway.
I would like to be able to torrent on the box as well
Thanks for your help guys!
EDIT: headless deployment is also important
blundakat
